Jerry's Evolving Thoughts on "new-to-me" Prime Premium
Discussion in 'Prime Main Forum (2017-2022)' started by jerrymildred, Mar 12, 2019.
  1. Tideland Prius
    16,598
    lol. Although the one time I looked under the hood of my Gen 3 and I found maggots...
    so.... :sick:
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Back in the day, we had a Dodge A108 van. My Mom took it to a shop to get new tires, and the kid with the large impact wrench promptly sheared off three studs on the left side. He didn't notice the little "L" on the end of the stud which indicated left hand threads and only started asking questions after the three studs broke. Left hand threads were common on Chrysler products in the 60's.
    It also reduces running torque, so you would need to raise your torque a bit to get the same clamping pressure. Torque tables have both a dry and lubricated column for torques.
    Or just use plain water and a few drops of soap in it. Won't freeze this time of year.
    #382 jb in NE, Apr 16, 2019
    jerrymildred, padroo and Prodigyplace like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Well that’s positive reinforcement :eek:.
    I’d think twice about what’s under the hood if that’s what our Prius ran on:p.
    You Canucks(y).
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I remember those days.
    And then there was our adventure on the way from Lomé to Mango, Togo four years ago. Flat tire and one stud was spinning. So they cut it off. After that we went on down the road missing TWO studs on the right front. Until most of the belts broke on the engine and the driver had to hitch a ride on a motorcycle to the next town and bring back enough belts to at least run the engine. (A/C was a luxury since it was barely over 100F.)
  5. Prodigyplace
    12,625
    11,807
    Central Virginia
    That looks like quite the Prime! :D :ROFLMAO:
    jerrymildred likes this.
  6. jerrymildred
    11,517
    14,157
    Tampa, FL
    I'm afraid a Prime or any Plug-in would die young there. The electricity is REALLY bad. As are most of the roads. :( You need one of the Landcruisers specifically built for Africa, like my friend, Adam, drives. Yeah. Actually, no hybrid would last long there now that I think about it. :whistle:
    Prodigyplace likes this.
  7. jerrymildred
    11,517
    14,157
    Tampa, FL
    Vacation preparations are beginning.
    I posted this in a new thread, but will add it here. I finally found something that actually works to block the glare on the 11.6" display. Now, instead of a blinding light, that part of the screen just turns white.
    Leaving in a few minutes to get the new tires put on and alignment done. Going with the Yokohama Avid Ascend GT all season. The price is just too good and it gets very good reviews. All my previous Prii had Avids, too.
    And since the wife is bugged by sweat from the seats, I have seat covers on the way. Going with some inexpensive but well reviewed red & black universal ones because I just don't have enough money left now for custom ones. Bound to be better than a beach towel. :D
    #387 jerrymildred, Apr 19, 2019
  8. jerrymildred
    11,517
    14,157
    Tampa, FL
    New tires installed. Service writer was a nice guy, but didn't know much about the Prime since I think this dealership has only sold about three of them. I told him that I have over 1,700 miles on this tank and it's still just a whisker under 3/4 full. His eyes almost popped out of his head and he suddenly had lots of questions about plugging in and what it actually cost me to drive. After I told him that it's about two cents a mile for the electricity I actually have to buy and that I've pulled about 175 or so kWh from my wall in those 1,700+ miles, I sensed that he was starting to want one. (y)
  9. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Let us know your thoughts on these tires after your upcoming trip.
  10. thefranchise713
    thefranchise713 Junior Member
    75
    52
    Buffalo, NY
    2018 Prius Prime
    Second that. I'm just itching for an excuse to rip off the Toyos.
  11. jerrymildred
    11,517
    14,157
    Tampa, FL
    Well, it wasn't a thorough test of the tires, but I did put 38 miles on them yesterday. 19 miles of it was on the route to & from work. They at least were not louder than the Toyos. Maybe slightly quieter. I took some corners fairly aggressively. The car was on a rail. It had stopped raining and the roads were pretty well dried, so no report about wet handling.
    As for effect on mpg, that's hard to say because it was very windy. However, looking at the miles/kWh bar chart, it seemed like I was consistently slightly under 5 miles/kWh while I had been slightly over with the old tires. That might have been the weather, but I would not be surprised at a small hit till the tires limber up.
    Edit to add. I almost forgot. I did have them out in the wet earlier in the day for about 4 miles. Serious puddles!! No hydroplaning, but it was all local street speeds of about 35 or so mph.
  12. jerrymildred
    11,517
    14,157
    Tampa, FL
    'Nuther tire update. The Yokohamas seem to be breaking in after a couple hundred miles. I was in the mid 4's for m/kWh for quite a while but it's creeping back up. Yesterday's eco diary had me at 5.1. Still not back to the level of the Toyos (mid-upper 5s), but it hasn't leveled off yet, either. And some of that difference is probably due tot the increased tread depth creating a larger diameter and very slightly reducing the odometer reading over the same distance. Oh! And they are also at least as quiet as the Toyo Nanos.
    I did read an encouraging comparison test from TireRack dot com of these tires against the competition from Goodyear, Michelin, & Continental. Here's the summary:
    thefranchise713 likes this.
  13. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    With less tread, there is less tread squirm and generally less rolling resistance.
    Prius from Dad and jerrymildred like this.
  14. JC91006
    JC91006 Senior Member
    16,813
    8,595
    I've been so busy moving this past month, didn't realize so many members upgraded their rides. Congrats on the new Prime!! I'm leaning towards the new hybrid Rav4 for my upgrade, need the extra room
  15. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    While some of us swapped to Primes, what you are considering @The Critic is also considering :).
    And @royrose has already converted ;).
    Tis the season(y).
    jerrymildred and JC91006 like this.
  16. jerrymildred
    11,517
    14,157
    Tampa, FL
    Moving will do that to ya! :D It seems like there has been a sudden surge in upgrades to Prime lately. But if you need more room, the Prime sure would not help. But I have found that, so far, it hasn't hurt compared to the PiP like I was afraid it might.
    JC91006 likes this.
  17. jerrymildred
    11,517
    14,157
    Tampa, FL
    Update on fuel use:
    I just turned over 2,000 miles yesterday on this tank. Gauge is still reading over 5/8 full. I'll top it off a week from today before we head west on vacation and see how the numbers crunch.
    Yesterday's m/kWh with the new tires reverted a little. Only got 4.8 or 4.9 m/kWh. Traffic was a factor, but not enough to account for the entire difference. Can't wait to get it out on a road trip to see how it compares to the PiP.
  18. jerrymildred
    11,517
    14,157
    Tampa, FL
    This afternoon, when I ran out of EV range, I had the presence of mind to reset the Trip A trip meter. Over the remaining 17 + a fraction miles home, it returned 75.7 mpg on country roads with 50-54 mph with several stops. I don't think the PiP could have come close to that.
  19. Prodigyplace
    12,625
    11,807
    Central Virginia
    The only time I remember getting that high with my Gen 4 was in some "city driving"
  20. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Just did a trip back from the California Ag museum. Was able to get 175 mpg on the way up and pitched the battery. No charging areas there:(.
    On the way home averaged 66.4 mpg displayed for 35 miles traveling 65 mph :).
    This trip would have yielded only 47-49 mpg in our old Gen3. Even with a pitched battery, this is much better(y).
    #400 Raytheeagle, Apr 28, 2019
