MPG 4MPG lower after Software upgrade/Recall
Discussion in 'Gen 3 Prius Main Forum' started by jl2013Prius, Jan 14, 2019.
  1. Mendel Leisk
    38,981
    I was thinking car servicing shops in general could benefit from doing this. Window tinters and detailers as well. Save a lot of down-the-road hassles.
  2. jl2013Prius
    jl2013Prius New Member
    Maryland
    Update: halfway thru 2nd tank of gas and things have returned to normal. Consumption reading between 47 and 48MPG; that's as good as it gets with Winter/oxegenated fuel in the Mid-Atlantic area. I'll chalk it up to the computer "relearning" my driving patterns.
  3. jack black
    jack black Active Member
    225
    142
    I
    i thought you pumped up the tires too?
    thanks for the update, I just got the recall letter. need to find time now.
  4. jl2013Prius
    Maryland
    I pumped up the after approx 25 miles after getting the car back from the dealer since I noticed right away the lower numbers after each drive; that didn't make any difference. The car started to show normal MPG figures approximately 150 miles after the the software was upgraded.
    Robert Holt, audiodave and Bay Stater like this.
  5. bisco
    49,810
    good news (y)
  6. GorData
    GorData Junior Member
    NYC
    Have an appointment for this upcoming Saturday morning. Will keep an eye out to see what happens afterward.
    Bay Stater and amos like this.
  7. marvingloria2011
    marvingloria2011 Active Member
    109
    162
    Winnipeg, Manitoba, Canada
    Got mine done today. Let's see how it does in a couple of tanks of gas...
    mjoo and audiodave like this.
  8. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    Had mine done yesterday, no problems with mpg but there are some different things going on.
    Noticed I can now drive in EV up to 48mph as opposed to 45mph before when the ice kicked in..... Let's see what else happens.
  9. taxidriver50005
    204
    170
    GB
    Excel
  10. taxidriver50005
    204
    170
    GB
    Excel
    Could be wrong but I think it's running a little bit more in EV mode since update.... Think I was getting around 48% EV before. Screenshot_20190216-015519.jpeg
  11. Mendel Leisk
    38,981
    This is the 2nd inverter software update. I noticed after the first update that the car went electric-only a bit easier.
    Have yet to get this latest update; I will in the next month or so.
  12. boywander
    boywander Junior Member
    37
    Washington
    Recall letter with update firmware came in the mail. I’m waiting to see what everyone’s consensus is before I get it to the dealer.
  13. boywander
    37
    Washington
    How did you get your car info to display like that (mobile app)?
  14. taxidriver50005
    204
    170
    GB
    Excel
    Hybrid assist on play store for Android. Very helpful live data
  15. john1701a
    john1701a Prius Guru
    12,761
    5,247
    57
    For example, my latest share...
  16. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Does this smart phone app run off a Bluetooth diagnostic module? Thanks.
  17. john1701a
    12,761
    5,247
    57
    Yes, and it has a tracker to record the data. So, there's lots to look at afterward. It's handy when you need detail to diagnose or simply learn about something.
    Bay Stater likes this.
  18. taxidriver50005
    204
    170
    GB
    Excel
    OBD-II bluetooth adapter for about £5 is all I use
  19. TheCarshipPleiades
    TheCarshipPleiades New Member
    Virginia
    I got my update done last week and I noticed the same problem. Its the first issues I have had with the car and the reason why I found myself here.
  20. BZzap!
    BZzap! Senior Member
    1,607
    877
    Due to pending registration renewal I had to have the recall performed this week. I have to say that the temperament of the car seems to be normal. However, the fuel mileage seems to be affected in the negative. I drive a very specific route every day so I can easily gauge any changes in fuel consumption. After a week the fuel MPG is slowly dropping down. Each trip there is a steady decline of about 0.2 mpg. I guess that Toyota’s EPA estimates of 50 mpg seem to be no longer valid.
    amos, Bay Stater and Mendel Leisk like this.
