Changing transmission fluid
Discussion in 'Gen 2 Prius Main Forum' started by AVS1, Apr 21, 2019.
  1. AVS1
    AVS1 Junior Member
    32
    26
    Chicago
    Hey everyone, kind of a rookie question - a few months ago I had a fuse box rebuilt and the mechanic suggested changing the transmission fluid. I have this picture which samples with the fluid looks like.
    I believe this is a simple job - I got a guy with a lift that ven get it up - can someone walk me through whether I should do it and what fluid, etc.
    I know it sounds dumb but I thought I heard somewhere that if you put in new transmission fluid after it’s really dark you can actually have adverse consequences.
    220k Miles
    Not sure if done before.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,518
    Bay Area, California
    2019 Prius Prime
    There is no adverse effects to changing the fluid;).
    I’d swap it out especially if I had access to a lift, which will make the process very easy:).
    Enjoy your Easter weekend (y).
    Skibob, edthefox5 and SFO like this.
  3. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Do it, or DIY.
    At a minimum, use the Toyota WS ATF.
  4. Mendel Leisk
    41,103
    Some info in this, though no mention of change. Use only Toyota ATF WS, 29 ft/lb for both bolts, remove the fill bolt first. Replace the washers (check with dealership, they should have, two diff sizes?). Fill with the car level. Funnel with hose extension from above is easy method. When fluid starts coming back out level is correct. Should take 3.8 liters (4 US qts) At least one of the bolts is socket head cap screw with 10mm socket?
  5. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    "remove the fill bolt first" is a very good advise. If one removes the drain bolt first and then isn't able to remove the fill bolt, there will be a problem.
    The washers are the same (# 90430-18008). I've bought mine two weeks ago, because I planned to change the ATF too, but I just didn't found any time since then.
    You'll need a 10 mm Allen key and a 24 mm nut. The torque for both bolts is 39 Nm. (Feel free to convert in non-metric units. )
    Take care not to open the inverter coolant drain bolt next to the ATF drain bolt!
    Look here the pic in the second green rectangle, the sixth pic after that and the eighth pic after the sixth:
    Getriebeölwechsel – Prius Wiki
    SM-G950F ?
  6. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    There are transmissions that might potentially have an issue changing the ATF, it is just not ever an issue in the Prius.
    There are transmissions with internal clutches, going from a thick gooey old fluid to a thin new fluid, might be bad if it has internal clutches. The Prius only has one gear and no internal clutch, so it is not an issue.
    There are transmissions with hydraulic logic deciding what gear you should be in, draining that may lodge some debris in a passage and alter how the trans mission shifts. The Prius does not shift, and has no Hydraulic logic.
    ATF density can alter how the Torque Converter works, allowing more or less slipping from a stop. The Prius has no Torque Converter.
    A really obnoxious mechanic pointing out hazards a Prius just doesn't have:
    A mildly obnoxious person pointing out hazards a Prius just doesn't have:
    (he calls the hydraulic logic a valve body, but shows all the little passages)
    #6 JimboPalmer, Apr 21, 2019
  7. AVS1
    AVS1 Junior Member
    32
    26
    Chicago
    Wow this is an incredible community. You’ve given this mouth breather enough info (to have my mechanic friend do it).
    I’ll be sure to pass this info along as I am not sure if he wrenches on Prius’ ever.
    padroo, Skibob and Raytheeagle like this.
  8. Mendel Leisk
    41,103
    10mm Allen key socket? Not sure how to name it, but basically one of these:
    As opposed to:
    An extra-length ratchet is good too, for breaking them loose.
    Raytheeagle and MickyMatter like this.
  9. MickyMatter
    260
    168
    Germany
    That's exactly, what I meant.
    Sorry for my English, as I'm German.
    I would prefer the first one too.
    The other one (at least with a pipe) should do too. But this could end bloody.
    And for the second bolt a normal 24 mm nut will be needed.
    SM-G950F ?
  10. Mendel Leisk
    41,103
    I wasn't sure what to call it either, resort to pictures. :)
    Honda's also have "socket head cap screw" for transmission drain/fill bolts, but with a 3/8" (or 10 mm?) square hole. Many years ago, planning to do a transmission fluid change I phoned up the service department, asked if they had a special tool for that. The service writer dutifully asked a mechanic, came back and told me how they just use one of these:
    Skibob likes this.
  11. MickyMatter
    260
    168
    Germany
    If Honda uses a 10 mm square or 3/8" (=9.525 mm), then a 3/8"-ratchet without a nut will fit.
    But the Prius has a bolt with a 10 mm inner hexagon and one with a 24 mm outer hexagon shape. So one has to use the proper nuts with the ratchet.
    SM-G950F ?
  12. padroo
    padroo Senior Member
    2,763
    2,252
    Tell your mechanic it is just a simple planetary gearbox, he should know what that is.
  13. qmanqman
    qmanqman Active Member
    413
    136
    CO
    New guy here gonna change the ATF in my daughter's 2007. Is this the right stuff and am I getting it at the right price?
  14. Mendel Leisk
    41,103
    Yes it's the right stuff. Price a little high. Check with dealership parts dept too: they should have replacement washers too.
  15. qmanqman
    413
    136
    CO
    Thanks for the reply. I did a whole lot of reading and decided to go with Maxlife ATF that meets the Toyota WS spec.
    Here's the funny thing. Once the fluid started to drip as I drained the old stuff, I jacked up the rear end as high as I could with a floor jack. It started to run a small stream for a couple minutes and then got back to dripping. I let it do that til it nearly stopped. I put it back down on the ground and when I filled it up it took about 4 1/4 qts. This car's manual says capacity is 3.6 qts. All I could figure is that jacking up the rear unleashed another half quart or so. Anyone else ever tried this?
  16. Mendel Leisk
    41,103
    Close. The second gen owners manual says 3.6 liters, or 3.8 US quarts.
    The 2nd gen repair manual says 4.0 US quarts is "capacity", though that might be filling a brand-new, dry transaxle. 2nd gen manual doesn't "acknowledge the concept" of changing the fluid; 3rd gen is better in that regard, but still doesn't include it in the maintenance schedule.
    Bottom line, the correct level is achieved by adding fluid while the car is level (typically raised as well, for access). When fluid starts coming back out of the fill hole, you've added enough.
    There are lots here using alternative fluids, hopefully will work out for you. I'm a little incredulous though, when the manufacturers of these fluids say they "meet the spec" or words to that effect. As far as I know, these assurances are solely by the makers of those fluids, not by Toyota. Toyota's stance, in the Owner's Manual, is that any alternatives to Toyota ATF WS fluid "may" damage the transaxle.
    Again, lots here are using alternates, and so far so good. But Toyota doesn't recommend any other fluid.
    jerrymildred and MickyMatter like this.
  17. qmanqman
    413
    136
    CO
    Toyota also recomments Toyota engine oil in their owners manual but we all know that's a joke.
    Years ago Valvoline said right on their container that it is not to be used in Toyota WS CVT transmissions. They've since changed their tune. Valvoline has been in the lubricant bidness for a long, long time. I doubt that they threw that onto their packaging just for the hell of it.
  18. Mendel Leisk
    41,103
    I've not seen that. I believe they only spec a grade and weight. Page number?
  19. qmanqman
    413
    136
    CO
    Next time I'm in her car I promise I'll take a picture if I can find it. I spent yesterday chainging the downstream sensor and rotating the tires and looking up ATF change and a whole list of preventative maintenance things she needs. I'm sick of that SOB already LOL.
  20. Mendel Leisk
    41,103
