PriiDash(TM): Enhanced Instrument Panel / Data Logger - Now Open Sourced!
Discussion in 'PriiDash (TM)' started by 2009Prius, Jun 26, 2011.
  1. baradhili
    baradhili Junior Member
    Australia
    Silly question... but how to run this in linux? I can see it runs under cygwin, so theoretically it should run under straight linux...
    @2009Prius
  2. baradhili
    Australia
    duh.. and then I read the latest comments... well will git it a go..
  3. vitecd
    vitecd New Member
    NZ
    Hi there,
    now can I check if my adapter is ok?
    I've got 1.5 ELM 327 and can chat with it a few commands through PuTTY at 38400.
    Can I get the list of commands to check?
    Doing nothing in the car, freezing for a long time and nothing next. Thank you.
    Prius 20, W 10
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Sorry I haven't touched this stuff for a long time. Google for ELM manual should give you something to get started. Good luck!
  5. vitecd
    vitecd New Member
    NZ
    I'm just worried that my adapter is too new? As I mention it is 1.5. And related to the info from the internet my one responds a little bit differently.
    The most important question, is how to set up the COM port in windows? I've been writing COM5 in XML file.
    #205 vitecd, Feb 17, 2023
  6. vitecd
    vitecd New Member
    NZ
    I've been chatting with my ELM and as I can see, it can not change the baud rate and has no reaction to ST commands. Probably a bad fake.
