Battery Dying Way Too Soon
Discussion in 'Prime Main Forum (2017-2022)' started by maiki, Apr 22, 2019.
  1. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    If you don't turn on the car, the traction battery won't charge the 12V. You don't need to run your car on ICE, just turn on it, it should charge the small battery.
    Also, it might be a good idea to buy a small battery charger with jumper cables. I think it just needs very small amount of electricity to boot the system in stead of crank the ICE.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    There is no way this should be needed for a one week duration. Something is goofy on that car to kill the battery in a week.
  3. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    This is actually a good idea, not so much for yourself, but for others. Since you can’t jump anybody with your Prime, you can offer this instead. A little easier to carry than jumper cables, too.
    Unsupervised!
  4. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Since you can't jump anybody with a Prime, who is carrying jumper cables?
  5. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    Strictly a comparison since jumper cables take up as much space as the EVSE. Also in case anybody is thinking about taking them along for the ride. Like carrying a spare.
    Unsupervised!
  6. bisco
    52,373
    jumpers can be helpful when you need a jump
  7. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    I hope you still take it to the dealer. It’ll be a written record of it happening and if enough of this happens then this might prompt Toyota to look into it.
    Unsupervised!
  8. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Good point. I had forgotten needing power.
  9. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I'll have to rethink this strategy if I leave town for a few weeks without taking the car. Leaving it plugged in for 2-4 days without driving the car has not caused problems. From the owner's manual:
    "When the vehicle is left with the charging cable connected, the electricity consumption amount of the 12-volt battery increases due to controls, such as the system checking, operating. When the charging cable is not needed, immediately remove it from the vehicle."
    bisco, jerrymildred and Trollbait like this.
  10. NSXT
    NSXT Active Member
    137
    119
    Toronto, Canada
    2018 Prius Prime
    Were you referring similar to this? https://www.costco.ca/Boostmi-Pro-Portable-Jump-Starter-and-Personal-Power-Supply.product.100410499.html
  11. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    This one has had good reviews from a few friends:
    jerrymildred likes this.
  12. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Ah,Ha.
    Finally, the question of why is answered.
    You leave the Traction battery cable inserted for days and all the while there are parisitic electrical drains.
    And in this thread you state that after driving for twenty minutes the 12v was still dead, well, the 12v needs to be fully charged, or it will not hold enough of a charge to start the prius, hopefully, anyone else that has the same habits will learn from this thread.
  13. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I don't think so. The OP noted that "No, it wasn't plugged in when not in use", so it wasn't the parasitic drains that was causing the original problem. Either OP's battery is not holding/accepting a charge, or the car isn't charging the 12V properly.
  14. Trollbait
    12,676
    The SKS could easily be the culprit. Earlier Prius generations had a switch to turn it off for when leaving the car parked for extended periods. There could be a 'hidden' way of turning it off on the current model.
    Lead acid battery life is shortened with deep discharges. Once drained dead, the chance of dying again goes up.
    drash likes this.
  15. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    Yep. The cutoff for lead acid is 50% discharge. Lifetimes are shortened by temperature and the amount of time left at discharge as well.
    iPhone ?
  16. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I have that exact same one. So far, I've never needed it. But it does seem to hold its charge for a long time.
  17. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I think there is a setting for this in Carista. "Stop monitoring for car key signal after..." then enter the number of days.
  18. bisco
    52,373
    gen 4 Sks can be shut off with fob. not so with prime?
  19. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Edit - there is a way to do this, page 280 of the Prime owner manual. It is titled "Electronic Key Battery-Saving Function."
    Learned another something new today...
    #39 jb in NE, Apr 24, 2019
  20. bisco
    52,373
    that's too bad. i wonder if it wouldn't fit because of the remote conditioning.
    as far as sks is concerned, it has never affected my pip in the 10 weeks i let it sit.
    bruceha_2000 and jb in NE like this.
