Auto Reset of Avg Fuel Consumption Readout
Discussion in 'Gen 2 Prius Technical Discussion' started by ekpolk, Aug 30, 2006.
  1. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    According to my owner's manual (for the 04, pg 151),
    My preference would be for this readout NOT to reset automatically upon refueling (obvioiusly, I don't care about the button-push reset...). I've searched here and via google, and have found nothing. Is there a way to set the system so it won't auto-reset upon refueling? I want the average fuel economy to remain, unchanged after refueling, as a "stable target" I can keep shooting to refine. TIA.
  2. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    <div class='quotetop'>QUOTE(ekpolk @ Aug 30 2006, 10:48 AM) [snapback]311608[/snapback]</div>
    As far as I know there is no way to avoid the automatic reset.
    On your next tank, notice how it behaves. In the first few miles the MPG will be all over the place. I usually fill up at a station close to work. Running EV most of the way to park, the readout will be 99.9. But leaving it will quickly drop to the 40's or even the 30's by the time I exit the campus. After a couple hundred miles a mile or so of EV will up the mileage by only 0.1 or 0.2 MPG.
    If it did not reset and you get a thousand miles or more, it will rarely change. Ten thousand and you will think it is broken.
    The best option would be to use a PC or PDA program to track it. (I use TealAuto on a Palm, but there are a number of other options.) This way you can track how the mileage changes with seasons and experience. This will also provide a total mileage reading.
  3. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    it resets when you add 3 gallons. so you could add 2 gallons at a time, but that sounds like a pain.
  4. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    <div class='quotetop'>QUOTE(jfschultz @ Aug 30 2006, 12:28 PM) [snapback]311662[/snapback]</div>
    Uh oh, I feel a TonyPSchaefer post coming on... ;)
    (he has a very good spreadsheet showing average MPG and average temperatures, check out his profile, there's a link there somewhere).
    The first time it reset on me, I was a little upset, because I thought there was a way to keep track of lifetime MPG. But that has to be done on old-fashioned paper, or PDA/spreadsheet... but not on the MFD.
  5. Tom_06
    Tom_06 Active Member
    609
    143
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(nerfer @ Aug 30 2006, 02:40 PM) [snapback]311695[/snapback]</div>
    The early 2006 models do not reset the MPG number, only the miles on the tank (even though the manual says they both reset). Does your 2006 reset both? If the MPG display does not jump around for the first few miles after getting gas, then it is not resetting. I had not heard of anyone with a 2006 that has the old 2004/2005 behavior.
    I always hit the reset button after getting gas because I want both miles and MPG to reset. On a long trip, I might leave it alone to get MPG for the entire trip.
    - Tom
  6. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(ekpolk @ Aug 30 2006, 11:48 AM) [snapback]311608[/snapback]</div>
    The problem is that it would be too stable. I don't believe it would do what you are hoping for.
    Lets say your MPG calculation never reset. If you achieve 50 MPG for gallon for 5000 miles,then you MPG calculation would read 50 MPG. All good, right? But then lets say you got 10 MPG for the next 300 miles. At that point, your MPG calculation would read 47.7 MPG. Is that what you would want it to do?
    After several thousand miles, the collective weight of all of the previous miles would make it so stable that it wouldn't be very useful.
  7. bweather
    bweather New Member
    <div class='quotetop'>QUOTE(Marlin @ Aug 30 2006, 02:07 PM) [snapback]311708[/snapback]</div>
    Eh... Y'know, I was just going to leave mine without resetting, so I could have a lifetime average without having to calculate it myself, but that's a really good point.
  8. ekpolk
    548
    176
    2018 Prius
    Two Eco
    Thanks for the all responses. Yeah, Galaxee, I had considered beating it by frequent refueling, but realized that would fuel not only my car, but also, my awful case of OCD. Gee, with all that touching of gas pumps, just think of how often you'd have to wash your hands. . . ;) More seriously, of course, one of the very reasons for having a Prius is visiting the gas pumps less frequently!
    Marlin:
    What I was really hoping for was a happy medium that I could control, according to my actual use of the car and preferences. Reset it once for a week of commuting, or for a road trip, or a weekend, etc. You're describing one extreme, accurately and sensibly. At the other extreme (what my 04 does regardless of what I want), the avg econ readout is pretty worthless for about the first quarter to third of each tank, as the figure just jumps about willy nilly from one block or freeway exchange to the next.
    Sounds like they changed this for the 06 models? Anyone know if I can get my car's software upgraded? That would be nice. [​IMG]
  9. dvdirv
    dvdirv Member
    144
    Atlanta, GA
    <div class='quotetop'>QUOTE(ekpolk @ Aug 30 2006, 05:39 PM) [snapback]311778[/snapback]</div>
    I have owned both an '05 and now an '06 Prius. The '05 Prius would automatically reset the MPG upon fillup, while the '06 does not--only the mileage driven since last fillup automatically resets.
    Hope this helps!
  10. santoro1
    santoro1 New Member
    132
    <div class='quotetop'>QUOTE(dvdirv @ Sep 1 2006, 11:44 AM) [snapback]312759[/snapback]</div>
    unless of course you do what I did....The MFD had some finger prints on it...sooooo while the car was on I decide to gently wipe the mfd....bingo reset button pushed... :eek:
    Moral of the story...shut the car off before cleaning MFD!
  11. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    <div class='quotetop'>QUOTE(ajs @ Sep 8 2006, 11:52 AM) [snapback]316491[/snapback]</div>
    Or shut off the MFD before cleaning it, if the car is on ;)
  12. mtsarpilot
    mtsarpilot Junior Member
    87
    I've put 4 tanks of gas in my '06. On the first one the miles reset. Since then, nothing has ever reset automatically. Perplexing.
  13. bdmclacken
    bdmclacken New Member
    Antioch, CA
    You might try turning the car off, then hitting Power twice with your foot off the brake to get into the 2nd ACC mode (forget what the term is for 2nd Power on mode). I would do that while filling up if I had passengers so they could listen to music while I was out or play with the navigation, etc. I noticed that this tends to interfere with the car recognizing the fillup has occurred which would trigger the reset... neither the miles nor the MPG got reset at my last fillup when I did this. I have an 06, just got it a little over a month ago.
    Being pretty new to the car, I actually wanted measurements taken per tank so I can tell if I'm improving my driving and MPG, so I reset it before I pulled away. I suppose later on down the road, this little trick might come in handy if I want to take measurements that span a few tanks like a road trip (a really long one) or the length of a summer or winter season or something.
  14. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    So, this reset occurs after the vehicle is stationary and the fuel
    tank content rises by some delta. It would be an interesting
    experiment to see if the reset occurs when fuel is added WHILE
    MOVING, or at least registering some nonzero VSS value. This could
    be done electronically, or by physically lifting one front wheel
    off the ground and letting it slowly spin in "creep" while pumping
    in gas. The electronic-only approach would probably be less likely
    to weird out gas-station attendants, though.
    Hmm. I've already got easy access to the wheel speed sensors, and
    there's a tone generator kicking around the shop somewhere...
    _H*
  15. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    I really prefer te tank-to-tank method of attacking FE. It's nice to start fresh and see how high your numbers can get in a short period. And it gives you a target you can actually hit, and have some impact on.
    Ultimately a running total on paper (or spreadsheet software) is a really good idea regardless of what the MFD says. You can track more than just miles and FE that way; I have dollars per tank, price of gas, days between fills, avg temperature, and a bunch of different comparisons on my spreadsheet, and it's a great way to see how things change and why.
    It's a good idea to do the same for your non-hybrid cars (ok, maybe not EV cars) as well, if you're unlucky enough to have them. ;) Not just for comparison to your Prius, but also because you can make small differences in other cars just like you can in the Prius. It all makes a difference.
  16. marjam
    marjam Member
    220
    Silver Spring, MD
    My '01 never reset itself and I liked that. Then if I took a trip that was longer than one tank of gas I could get the mileage for the trip. My '04 did the same thing until the first computer recall and since then it resets at each fillup. You usually have to drive about an 8th of a mile before the reset. I am with the OP. I think it should not reset unless the driver wants it too. I am all for having as many driver preferences controllable as possible. It sounds like to get what I want would take a computer downgrade back to the way it originally was!
  17. Alnilam
    Alnilam The One in the Middle
    760
    Carlsbad, CA
    <div class='quotetop'>QUOTE(hobbit @ Sep 9 2006, 06:28 AM) [snapback]316919[/snapback]</div>
    I used to do this in a B-52 behind a KC-135. I can verify that the fuel guages do reset then. And you're right, it is interesting, especially during bad weather at night.
    It'd be fun to hook up a Prius behind a Hummer tanker dragging a hose in the breeze (over a bumpy road.) Trouble is, he'd probably run out of gas before we completed the refueling.
    "Breakaway, breakaway, breakaway!" (For folks who remember those days.)
  18. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    I just don't understand why Toyota didn't put a "lifetime MPG" feature on the MFD.
    I know the Honda Insight has it and I feel its a pretty useful number to have as a reference.
  19. ekpolk
    548
    176
    2018 Prius
    Two Eco
    <div class='quotetop'>QUOTE(Alnilam @ Sep 11 2006, 10:54 AM) [snapback]317735[/snapback]</div>
    Yep, I used to do it in an EA-6B. A 135, with "Iron Maiden" attachment, was the LAST thing I wanted to see from my friends in the USAF, even if I was running out of gas. Anything with a soft basket was better than that nightmare.
    And hey, I think you got it backwards -- we should probably be sharing some gas with the poor grasshoppers who bought the Hummer!
    Seriously though, I don't see why Toyota didn't give us the choice. Sometimes tank-by-tank resetting is fine. Other times, like on a long trip, I want to reset when I choose to do so. Hint Toyota: this would be a nice software upgrade for owners of pre-06 models!!!
  20. walkinghat
    walkinghat Junior Member
    27
    In my 07 the miles reset but the MPG does not. Might be because I put it in park instead of off since the engine isn't running anyway...
    I know I know... please don't call Homeland Security on me..
    I like the classic better in this regard. As long as you didn't press reset, nothing reset at fillup.
