please recommend a trahsmission fluid pump
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lester williams, Sep 19, 2014.
  1. Fostel
    Fostel Member
    96
    30
    Kent
    Excel
    I am sorry but I am a 'metric guy' is 1/2 inch OD a tube that has 13 mm outer diameter? Rubber or clear PCV?
    Would this work?
    Thanks.
  2. Mendel Leisk
    41,889
    The tubing on my funnel is somewhat oval (just from being coiled), and the larger outside diameter around 15 mm. It's clear plastic, semi-flexible. Not sure what the chemical make-up is; Poly-vinyl Choride I think (just looked it up). It's the run-of-mill stuff sold in hardware stores, or beer/wine making places. It fits the fill hole with a little room to spare.
    On third gen the fill and drain bolts (and their washers) are identical. If you buy washers at a dealership parts counter, you should only need to tell them a description, but if you want to verify:
    90430-18008
    Fostel likes this.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    This is the one I use. It is made by Assenmacher.
