MPG 4MPG lower after Software upgrade/Recall
Discussion in 'Gen 3 Prius Main Forum' started by jl2013Prius, Jan 14, 2019.
  1. Grit
    Grit Senior Member
    6,160
    4,064
    Wilkes Land
    Watch, theyll deflate your tires to 32 psi tricking you that you lost mpgs because of the software update.
    Bay Stater, Raytheeagle and RMB like this.
  2. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Nah that wouldn’t be one of the causes, because I always request 38 psi front and back, and if they messed it up, I pump it back up to 38 right after. :LOL:
  3. Grit
    Grit Senior Member
    6,160
    4,064
    Wilkes Land
    It happened to a fella here in PC though :p
    Some tire place told me by company policy, they must de/inflate tires to car’s psi spec before giving keys back to customer. Where’s the get the job right the first time company policy :p
  4. BZzap!
    BZzap! Senior Member
    1,607
    877
    The dealers policy is to adjust the tires during an inspection to the factory recommended pressure. This is due to liability concerns. Tire pressures are critical and every time the dealer does an inspection, the readings are documented. This is just a CYOA measure.
    Bay Stater and marvingloria2011 like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,483
    Bay Area, California
    2019 Prius Prime
    If you need some encouragement:
    The gas gauge is showing my consumption after 650 miles:).
    Wait til the next meetup for another reminder (y).
    Bay Stater, marvingloria2011 and RMB like this.
  6. Grit
    Grit Senior Member
    6,160
    4,064
    Wilkes Land
    Talk about peer pressure.
    marvingloria2011, RMB and Raytheeagle like this.
  7. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    So jello LOL! 650 miles and used about 2 gallons of fuel:love:
    Yup, but the good kind of peer pressure for sure!:sneaky:
  8. Raytheeagle
    11,251
    15,483
    2019 Prius Prime
    And that’s only because I forgot the charging trips the gfci if I don’t set the charging rate to 8 amps:cool:.
    I need a post it note to remind me so I avoid burning gas for no reason(y).
    Bay Stater, RMB and marvingloria2011 like this.
  9. marvingloria2011
    marvingloria2011 Active Member
    109
    162
    Winnipeg, Manitoba, Canada
    Man, that mileage is insane! I don't anywhere near that here in Winnipeg.
    RMB, Bay Stater and Raytheeagle like this.
  10. Raytheeagle
    11,251
    15,483
    2019 Prius Prime
    I’m definitely impressed (y).
    marvingloria2011, RMB and Bay Stater like this.
  11. cnc97
    cnc97 Senior Member
    1,422
    1,532
    Evansville, IN
    Sounds like you need a new GFCI. At least in my house, the GFCI will hold 15 amps. 20 on the one powering my sump pump in the basement.
  12. Raytheeagle
    11,251
    15,483
    2019 Prius Prime
    This is a work provided one ;).
    So I just deal with 9.5 hour charging, as I’ve been here a lot more than that recently:cool:.
    That is when I remember (y).
  13. nicoj36
    nicoj36 Active Member
    499
    159
    I was able to get my mpg back by performing a tune-up. New spark plugs, transmission fluid drain and fill, and oil change. And i was able to get my mpg back prior to doing the recall.
    marvingloria2011 and Bay Stater like this.
  14. ASRDogman
    ASRDogman Senior Member
    6,261
    3,336
    They cannot over or under inflate your tires, for liability reasons. But, if you already adjusted your tires,
    they are not required to change your tires. And if you tell them not to change the pressures, they are liable for doing unauthorized work on your car that you told them NOT to do.
    #74 ASRDogman, Apr 29, 2019
  15. Mendel Leisk
    38,952
    For me, jury's out if the update had some detrimental effect. It might have, but not sure. We've been helping out our daughter with her backyard blackberry infestation, and over the weekend was putting on a fair amount of kms, close to 200 now IIRC.
    This was on a fresh tank with the trip meter reset. Very easy driving, purposely going the long way round to avoid hill climbs, top speed around 70 kmh. The liters per 100 per 100 km settled down, to a tug-of-war between 4.5 and 4.6, mostly 4.6.
    Which will likely translate to calculated 4.9, which is our lifetime average. So I'm thinking: c'mon, should be able to better than this. 4.9 translates to 48 mpg (US gallons) btw.
    Factors that might explain (besides the software update):
    1. New tires, 215/44R17 Michelin Primacy MXM4. Michelin does give them the Green-X badge, their LRR tag, but they are also brand new. I've got them around 35 psi all round. Keep in mind regarding that pressure, they are the low profile 17's.
    2. Ambient temperature: it's still cool out, which has a direct effect on engine efficiency I think, and: the car is monitoring the ambient temp, and maybe changing behaviors accordingly. Maybe sacrificing some mpg for less pollution? Not sure.
    marvingloria2011 likes this.
  16. marvingloria2011
    109
    162
    Cool! I've got an oil change scheduled in the morning. Maybe I'll swap out the spark plugs and clean my Tom's Racing filter out and see how that goes.
  17. marvingloria2011
    109
    162
    This is great to know, since the majority of people here are from the United States. My overall average is a 6.5 L/100 km (calculated including the winter months of about -20 to -45 degrees Celsius and running 19" wheels during the summer months). This works out to 36 MPG with no effort to go the long way (which I should probably do for better mileage since it's 70 km/h there as well). Good to know.
  18. nicoj36
    499
    159
    Don't forget the tranny drain and fill. It's really easy. You'll just have to get a hose pump to fill it cause the fill-hole is under the car.
  19. cnc97
    cnc97 Senior Member
    1,422
    1,532
    Evansville, IN
    So I was monitoring the operation of the ICE today and I did see something different today. On flat level ground it went into electric only at 50 mph. Held it for almost 1/2 mile. 0 indicated ICE rpm. As soon as the road started uphill the ICE kicked in.
  20. ChapmanF
    15,998
    I generally just fish a hose down to the hole from up in the engine compartment from a funnel, and pour into that. You reach the fill hole from under the car, but it's on the side of the tranny.
    But I knew somebody with an Isuzu automatic transmission where the drain and fill plugs were both on the bottom of its pan. The fill plug was on a sort of stepped-up level of the pan bottom, matching the correct fluid level. You literally filled that thing up through a hole on the bottom.
    Bay Stater and Mendel Leisk like this.
