2013 Prius C, hybrid battery/Yaris?
Discussion in 'Prius c Main Forum' started by afacchin889, Apr 29, 2019.
  1. afacchin889
    afacchin889 Junior Member
    Victoria
    Technology
    When my hybrid battery dies, couldn't I just take out the battery and it would become a Yaris basically? Same engine, 1.5L.
    Thanks in advance for the replies.
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    No. Without the traction battery, the car won't start.
  3. Leadfoot J. McCoalroller
    8,113
    7,593
    Pennsylvania
    2018 Prius c
    Same size engine, but not the same engine. OK, it shares many parts with the Yaris engine, but the big difference is that the Yaris engine is Otto-cycle (high compression) where the Prius is Atkinson cycle, low compression. So the Prius version burns less fuel & makes fewer horsepower.
    But the hybrid transmission is sort of the trap- it requires both gas and electric systems to be operational to drive the car anything like normal.
    There's good news, traction battery prices recently came down.
  4. afacchin889
    Victoria
    Technology
    Sure the Prius C has saved me money on gas but then I'll have to purchase a new Hybrid battery in X years eating up all of those fuel savings to purchase a new battery. I should have just purchased a Yaris then, please correct me if I'm wrong about that.
  5. Leadfoot J. McCoalroller
    8,113
    7,593
    Pennsylvania
    2018 Prius c
    All depends on when you sell it. Time it right and you get out while it's good, get good dollars out and the new owner gets some fair miles before they have to do anything.
    Plus there's something to be said for the smoother transmission you get to enjoy for X years vs. the 90s-tech Yaris 4-speed. The Yaris might have been the cheaper choice overall, but you've got the better car for now.
  6. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Depends. It's around an 8k difference (new) between a Yaris and a PC. The hybrid battery seems to be going 150k + miles from the average-ish that I've seen. A new battery can be had for less than $3,500 installed at the dealership. It's even less if you can do it yourself.
    Hometown Hybrids in Texas will do it for $2400 installed.
    In my 115k miles, I'm averaging 50mpg. I've spent ~ $6000 on just gas.
    According to the calculator on fueleconomy.gov , I've saved $3,565 over a Yaris. So essentially, it's a wash after buying a battery if I had to buy it today.
    Andrew Facchin likes this.
  7. Andrew Facchin
    Andrew Facchin Junior Member
    25
    British Columbia
    Is there a way around the whole traction battery thing or must the hybrid battery be operational to engage the traction battery in the car?
  8. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    No, you need both components for the car to work. The hybrid battery also provides around 24hp, which you need when your max hp is 99.
    You can get brand new blocks like these (currently sold out, though) for less than $1500, and if you’re handy and/or with a little help you can replace everything yourself.. which means $0 for labor.
    With the cost of used cars and gas prices going through the roof right now, the Prius C remains one of the most fuel efficient and reliable hybrids you can get in the North America, and IMO $1500 isn’t an astronomical price to pay if it breathes new life into your vehicle.
    ETA: I wasn’t paying close attention to the different “A” names and wrote this response thinking you were the OP coming back to ask the same question 2.5 years later.
    #8 Pri3C, Dec 13, 2021
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Any Prius has no 12 volt starter motor, it uses the High Voltage battery to run the AC Motor/Generator1 to start the engine.
    Additionally, only Motor/Generator2 pushes directly against the tires, M/G1 and the engine only assist M/G2, never push without M/G2, so you have to have the High Voltage battery.
