Fuel cap release lever broken
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mikem42, May 1, 2019.
  1. mikem42
    mikem42 New Member
    Brighton, UK
    Active
    Hi all, recently the floor lever which releases the fuel cap loosened then broke, in our 2006 UK Prius T-Spirit. We are now unable to open the fuel cap as the lever is completely separated. Any clues as to how to open the fuel cap without this? Or do we need to pull up the floor carpet to access the cable that presumably is connected to the fuel cap? Thanks!
    52,421
    welcome!
    check your owners manual, there might be an interior release in the hatch, i'm not sure. otherwise, it's pull up the carpet and fix it, which is probably a good idea anyway.
  3. schja01
    schja01 Senior Member
    1,848
    1,228
    Chicagoland
    2024 Prius
    Limited AWD-e
    This applies to the Prius Prime:
  4. mikem42
    mikem42 New Member
    Brighton, UK
    Active
    Thanks chaps - actually I have a UK T-Spirit, 2006 but there's no option to select that in the Prius Chat settings! I solved it in the end (short-term anyway) - there's a little cable with a hammer-head end (?) which pulls open the fuel cap door. Pic attached!
  5. bisco
    52,421
    well done! maybe you can find parts at a salvage yard or eBay.
    mikem42 likes this.
