Car shakes at high speeds
Discussion in 'Gen 2 Prius Main Forum' started by Cjandrade89, Apr 30, 2019.
  1. Cjandrade89
    Cjandrade89 Junior Member
    Lynwood
    My car runs great, and that is until I run at a higher speed when it begins to shake on the front passenger side. Also, I hear a thump whenever I let go of the gas peddle and right away step on the gas again.
    52,026
    maybe axle shafts? start with alignment, tire balancing, cv joints then axle.
    how many miles on her?
    Montgomery likes this.
  3. Cjandrade89
    Lynwood
    Almost 200,000. I bought her with a salvage title. And I’m a delivery driver so I drive a lot. But the dashboard only shakes when I go faster than 70 mph
  4. bisco
    52,026
    that could be a slightly bent frame, are the tires wearing evenly?
  5. Cjandrade89
    Lynwood
    Those are some pictures. Do they help?
  6. Cjandrade89
    Lynwood
    I tried uploading a video but it seems to be to long to upload
  7. cyberpriusII
    1,157
    1,800
    Mars Hotel
    Lots of different possibilities....a couple that have potentially fatal consequences, one that springs to mind is a tire starting to separate.
    I would have it checked by a reputable shop, quickly -- like immediately.
    I HAVE heard of some people in backwards sorts of unfriendly areas such as rural Oregon who have rotated tires in such cases to see if that makes any difference, thus narrowing down the likely source of the issue. Of course, I would never do that --:whistle::whistle::whistle:---well, at least not anymore. Saving some bucks is not worth the possible "human cost."
    kris
  8. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Did you replace that part or did someone else?
    SFO likes this.
  9. Cjandrade89
    Lynwood
    The lower motor mount?
  10. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Yes. The mount in the picture appears to have been previously replaced as there are markings indicating such.
    Though hard to tell from those photos, the passenger tire might be wearing differently. Have you tried moving the passenger wheel over to the drivers side to see if the problem follows, if it does then I would try balancing the wheel next.
    wjtracy, Raytheeagle and Skibob like this.
  11. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Not good.
    You should get that fixed........before a wheel locks up or falls off.
    Seriously.
  12. Cjandrade89
    Lynwood
    I bought it used. I’ve been looking all over for one made with polyurethane but no luck.
  13. Skibob
    2,912
    1,505
    Northern California
    Have you tried rotating the tires yet?
  14. oil_burner
    oil_burner Active Member
    249
    126
    it sounds like you have a broken strut mount, but it's hard to diagnose these things online. a suspension shop should be able to give you an inspection and find the cause. You can remove the lower engine mount and fill the rubber section with polyurethane glue, I did this and it made a huge difference in stiffness. Lots of videos on youtube how to do that.
  15. Skibob
    2,912
    1,505
    Northern California
    Could the motor mount even make the dashboard shake at 70 mph?
  16. oil_burner
    249
    126
    it could, if the tire is not balanced properly and starts shaking, then other parts of the car not properly damped will also do the same. Sounds like something is definitely loose if torque from the engine is causing a thump.
    Another simple test is with the hood open, apply the brake and gas at the same time in D, then do it again in reverse. Have a friend look under the hood and see what is moving.
  17. sam spade 2
    7,035
    2,803
    2017 Prius c
    With some Prius models, if you push the gas while the brake is applied, what happens is exactly NOTHING.
  18. oil_burner
    249
    126
    if that's the case you can set the parking brake and do the same maneuver. Just don't stand in front of the car in case it lets go.
  19. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    The thumping could be bad ball joints. I had the same symptoms on my older minivan and wound up replacing the lower control arm assemblies. Look under and see if there is alot of play in that area.
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Instead of guessing take it to a tire store for a free suspension check. A good front end guy will find that fast.
    I can see the tires are done you need tires those will be terrible in the rain. Looks a like a really cheap tire to begin with.
    Not sure why your looking for a poly motor mount you wont beat the metal one that's in there looks like they replaced that part from a junkyard by the labeling which means it took a really hard hit to the front end if that part was damaged. Probably never had the front end aligned after the butch I mean assembly job.
    Skibob likes this.
