Help with Wipers Not Working
Discussion in 'Gen 2 Prius Main Forum' started by Kurt Kauper, May 6, 2019.
  1. Kurt Kauper
    Kurt Kauper New Member
    New York City
    The windshield wipers on my 2004 Prius recently stopped working. They stopped in a position at approximately 45 degrees. I can't move them manually. When they first stopped, they would jerk a bit, as if they were trying to move, but never leave that general position, although that stopped after a while.
    When I asked a mechanic about it, he told me that those symptoms indicated a broken motor. I bought a used motor and installed it, but the wipers still don't work. I suppose the used wiper motor could be broken, but I'm guessing something else is the problem.
    Any suggestions?
    48,988
    welcome!
    if you are going to diy, i suggest a look in the repair manual at 'techinfo.toyota.com'
  3. Kurt Kauper
    New York City
    Thank you!
    I just went to the website. It's an expensive subscription. Have you found that site to be reliable in providing information? I'm a little concerned about paying for a subscription then not getting the information I need.
    Thanks!
  4. Patrick Wong
    18,199
    6,464
    Measure voltage at the windshield wiper motor wiring harness connector socket when the wiper switch is on. If you don’t find voltage then either the wiring harness has a problem or the switch is bad.
  5. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    You don’t say so I have to ask. Have you checked the fuse?
  6. Skibob
    2,912
    1,496
    Northern California
    Could the switch fail so even the wiper park would fail?
