For Sale LED WHITE DRL YELLOW FOG LIGHT PNP
Discussion in 'Private Sales' started by Danger, May 6, 2019.
  1. Danger
    Danger Member
    175
    22
    Frisco
    The fog lights are in excellent condition. The DRL is a bright white that creates a halo effect around the fog light. It is very bright as you can see the output shot on the ceiling. The fog light output is a sharp yellow. I have everything wired up and tested on my Prius it will be a plug in play for the fog lights but not the DRL because everyone wires it up differently. These were bought from theretrofitsource. The only issue is there is a gap when installed as you can see from the picture. It doesn't hinder the output at all. If you are able to fab up a shroud your golden even if you don't they still look terrific. $65 shipped.
  2. Danger
    Danger Member
    175
    22
    Frisco
    Feel free to ask questions.
  3. boywander
    boywander Junior Member
    37
    Washington
    Not sure if it’s me or the pictures not coming through.
  4. Danger
    Danger Member
    175
    22
    Frisco
  5. LaJay007
    LaJay007 Junior Member
    El Segundo, CA
    Probably a dumb question, but...I currently don't have fog lights on my 2010 Prius, but I'd love to have some DRLs and Fog Lights. Would the fog light portion of these still be plug 'n play on my car?
  6. Danger
    Danger Member
    175
    22
    Frisco
    Yes the fog light portion is plug and play. It was installed on my car to show it working and the gap. You can always wore up the drl in the future.
  7. Air_Boss
    Air_Boss Senior Member
    4,218
    1,188
    New Yawk
    What did retrofitsource say these are compatible with? Includes Prius v?
  8. Danger
    Danger Member
    175
    22
    Frisco
    If the Prius V uses the same as foglights as the Prius sedans then yes. TFS only said it fits type t model cars. Which is a wide range. If you look up their morimoto xb foglight type t this fits what's listed.
    Air_Boss likes this.
  9. Air_Boss
    4,218
    1,188
    New Yawk
  10. Mendel Leisk
    41,826
    #10 Mendel Leisk, May 17, 2019
    Raytheeagle and Air_Boss like this.
  11. Air_Boss
    4,218
    1,188
    New Yawk
    You got it!
  12. Danger
    Danger Member
    175
    22
    Frisco
    SOLD
