Video -What's The Minimum Range A PHEV Should Offer?
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, May 5, 2019.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    I've generally respected these videos hosted by Ms. Gorden-Bloomfield. In this recent 6min50sec one, although the Prime is not mentioned, the Prime clearly meets her criteria for a bonafide PHEV.
    52,337
    it really depends on user need, it's good to have variety, just like bev's and gassers.
    i'm around 90% ev with 12-15 miles of range, but i'd love to have a heat pump and bigger battery to cover it.
    the trouble with reviewers is that they have no parameters to go by. so they try to give a practical real world results and let buyers decide what works best for them.
  3. Marine Ray
    1,139
    947
    Sparks, NV
    Concur on user need, I'm glad the consumer has choices based on their lifestyle.
  4. bisco
    52,337
    it will be nice if we ever reach a point where the same model has various battery configurations, as tesla is doing, but i realize this is very expensive for manufacturers.
    pghyndman and triggerhappy007 like this.
  5. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    Honestly, I think the Prius is almost perfect. I could use 5-10 more miles, but i have no problem getting to work and back in the Prime. Sometimes I'd like to stop somewhere on the way home and I can't do that in all electric.
  6. bisco
    52,337
    with a prius, you don't want so much aer that you never use the engine
  7. Leadfoot J. McCoalroller
    8,134
    7,641
    Pennsylvania
    2018 Prius c
    Seems incomplete to list an arbitrary distance.
    To me, it makes more sense to combine it with some other factor, for example:
    "15 miles per thousand dollars (sticker price over the price of the ICE version)" or
    "Consistently able to charge 0-100% in 8 hours on L1 plug"
  8. bisco
    52,337
    not following you
    will the engineer likes this.
  9. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    How about theoretical max. With a perfect battery, that's small and light weight, cheap, long life, and can be recharged over night.
    I would say 900 miles. That's more than a person could drive in a day.
  10. bisco
    52,337
    why would you want an engine?(n)
  11. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    I would love to have an extra 10 miles.
    Useable miles. not hidden battery reserves
    Marine Ray and pghyndman like this.
  12. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,691
    Somewhere in Wisconsin
    2013 Chevy Volt
    At the hobby level hv lithium battery chargers start around $50
    I would argue any Hybrid should have at least the option of a battery charger, even if it’s only 5 city miles
    Marine Ray likes this.
  13. Rmay635703
    2,669
    1,691
    2013 Chevy Volt
    Eliminate platform laws and the cost becomes almost zero.
    This is a legal issue driving cost not a technical one as many European cars offer 6 or more drivetrain options in the same model.
    Only difference there vrs here is one little law, overturn it and much more choice will come to the market overnight.
  14. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    On those cross country trips where there is no charger.
    benagi and bisco like this.
