Changes in the 2019 Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by ReDave, May 10, 2019.
  1. ReDave
    ReDave Member
    82
    25
    Central California, Sierra/Sequoia Foothills
    2019 Prius Prime
    11 Days with our 4th Prius, this one a Prime Advanced, Red. I am loving it!
    There appears to be some changes?
    1. the trip button seem to have added at least one level? something about A/C usage?
    2. I CANNOT find a way to add gas prices anymore, i have for years on my other Prii, but not this one.
    I suppose that is OK, my OCD could use a rest, but... i need confirmation, or my OCD will go into rabbit hole overdrive.
    930 miles last night, learning to toggle on/off the HV button.... no harm/wear, right? Especially if i try to do it while not under load?
    the Electric charge 'hatch' seem to lock/stick sometimes, i push in, and it will not pry open, so i push it back in and quickerly pop it back out...
    52,229
    there are 3 trip gauges now? perfect. i only have trip and tank. lifetime would be useful
  3. ReDave
    ReDave Member
    82
    25
    2019 Prius Prime
    I use trip B as lifetime, since 2010
    no this is some sort of A/C range or something...
    mine has 7 'trip' displays
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    I toggle the EV / HV button as well and have noticed that it does have a “knock” from time to time:cool:.
    So I’ll be adding an oil catch can to ensure there is no damage;).
    A trick from the Gen3 that may apply to the Gen4 and Prime. But I have the catch can and will find a mounting place soon(y).
    SFO likes this.
  5. ReDave
    ReDave Member
    82
    25
    2019 Prius Prime
    wrong thread, sorry
    so, instead, what is an 'oil catch'?
    Raytheeagle likes this.
  6. schja01
    schja01 Senior Member
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    If you put the charging socket cover in it's holder to the right of the charging socket and
    then forget to put it back and you try to close the hatch it will half lock. This happened to me
    when a friend I was demoing for decided to be helpful and tried to close the hatch before
    I replaced the socket cover. It's a real bit*h to get the hatch open when this happens.
    You need to remember two things:
    1) Always put the socket cover back before closing the hatch.
    2) If you do forget don't use a lot of force to close the hatch.
    These are my personal experiences. Maybe someone knows a secret to getting the
    hatch door open when it is "half locked".
    I fiddled with a wooden stick (so as to not damage the paint) and flashlight to get it to
    pop open by pressing the mechanism open that was preventing the hatch from doing so.
    Hopefully there is a better way.
  7. Salamander_King
    Salamander_King Senior Member
    11,023
    8,958
    New England
    Here is the list of 7 display by toggling "trip" button.
    snead_c, benagi and ReDave like this.
  8. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Here’s the Gen3 thread on the topic ;):
    Oil Catch Can, Eliminate that knock!
    Only 70 pages of reading enjoyment :).
    Here’s the catch can I bought for the Prime:
    6D56E43D-8B76-404D-A81D-B21995A60746.jpeg C0CE2BD1-98A0-4404-ABDA-21EB08CE056B.jpeg 03BD588F-40EA-4F2A-AF1A-0795ADC0B5D3.jpeg
    Happy reading (y).
    Mendel Leisk and ReDave like this.
  9. ReDave
    ReDave Member
    82
    25
    2019 Prius Prime
    Ahh. That is not in the 2017 O/M ?
  10. ReDave
    ReDave Member
    82
    25
    2019 Prius Prime
    Hmm. I wonder if I "half unlock"? I have had several good "open" experiences
    Thanks to you all!
  11. ReDave
    ReDave Member
    82
    25
    2019 Prius Prime
    Ahh. 8 with the AC one
  12. Salamander_King
    11,023
    8,958
    New England
    Yes, it is from 2017 manual. Your 2019 have changed?
  13. Mendel Leisk
    41,785
    How much oil can an oil catch can catch... ;)
  14. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    If it could only catch oil:p.
    I can tell you the sporacing can I have this time will only catch 4 ounces though;).
    But I’ll keep an eye on it before it fills up(y).
  15. Mendel Leisk
    41,785
    Is that a typo? Just browsing, looks kinda like:
    Mishimoto MMBCC-MSTWO-BK Compact Baffled Oil Catch Can
  16. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    On Amazon it was listed as sporacingrts;).
    So I did shorten that a bit :oops:.
    But should be effective (y).
  17. ReDave
    ReDave Member
    82
    25
    2019 Prius Prime
    I found an online manual, and i'm not sure where, but it does say 2017, and it did not mention the A/C part, and the fan icon on my car, maybe i found a non prime manual? hmm well thanks to you guys, i'm set!!
  18. Salamander_King
    11,023
    8,958
    New England
    You can get 2019 (or any other model year) owner's manual from Toyota Owner site. This is the link for your model 2019 PRIME. According to this, 2019 PRIME has the same 7 display as 2017 PRIME as I indicated above on comment #7.
    2019 Toyota Prius Prime Owners Manual and Warranty - Toyota Owners
    #18 Salamander_King, May 13, 2019
    ReDave, Raytheeagle and Mark57 like this.
