I am getting the maintenance required message thinking it's for an oil change
Discussion in 'Gen 3 Prius Main Forum' started by Freeze Time, May 17, 2019.
  1. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    2015 Prius and it's the first time oil change for me. Anything I need to know? It's definitely the oil change for the maintenance message right? Can I just take it to any old place and they will know what to do? Is there anything that's different from a regular car?
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yes the Maintenance Required light is for oil changes.
    No there is no difference between your car and other cars. There is a flimsy plastic flap that generally breaks off. If you're not doing it yourself, you'd probably never know (monkey sure isn't going to tell you!).
    And the maintenance light is not automatically reset. The car does not know when the oil has been changed. So you have to reset it yourself or make sure the shop does it.
    Bay Stater, kenoarto and Pluggo like this.
  3. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    The oil filter is a cartridge type that goes in a plastic housing. They need the right size filter wrench for it. It seems like half the shops overfill the oil, which is not good for various reasons. And how do you really know they are giving you the right oil and not something cheaper? It's always best to do your own oil change. Lay on your back. Look around. Get to know your car.
    Bay Stater likes this.
  4. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    kenoarto likes this.
  5. spiralhelix
    spiralhelix Active Member
    255
    217
    Illinois
    in ?not so nice way? saying shop/grease monkey...aka the person doing the work.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Maybe not.
    My C lights the light every 5K miles to indicate a tire rotation is due.
    Oil change is 10K.
    I compromise and do both at 7K.......or when I get tired of my wife yelling at me because the light comes on.
  7. bisco
    51,845
    actually, the 5k reminders are for service. look in your maintenance manual, and it will tell you what services are required by toyota at each one.
    how many miles on your car?
    Bay Stater, fuzzy1 and Mendel Leisk like this.
  8. Prodigyplace
    12,533
    11,755
    Central Virginia
    Nevermind. Misread first post.
  9. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    A little over 38,000. I bought the car with 33,000 on it.
  10. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    1) The service required reminder is a simple 5,000 mile counter--it repeats 5,000 miles since the last reset. 2) It can only be reset manually, so you should familiarize yourself with the simple procedure. 3) The oil change interval is 10,000 miles if you last filled with 0W-20 oil. Otherwise, it is 5,000 miles. 4) It's up to you to remember/keep track of when and what grade of oil was last used. 5) Toyota recommends a tire rotation and additional fluid level and brake checks at 5,000 mile intervals.
    fuzzy1 likes this.
  11. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    This is soo high maintenance, like being married and having kids. That settles it, I ain’t having neither.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    If you did, you’d never be able to keep your car the way you have it now:p.
    Removed the passenger seat yet:whistle:?
    Bay Stater, CR94 and Grit like this.
  13. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Haha. Not yet, that seat will stay after contemplating. Rained couple days ago and wipers were put back on, almost decided to put new plugs in before that but held off. Late next week I’m headed to the bay for my competition so the rear seats have to be put back in for my traveling needs.
    Raytheeagle likes this.
  14. bisco
    51,845
    do you know when it was last changed? i would poly do it at 40k, along with the other recommended services
  15. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    I’d do it now you’ll never know if the previous owner said “What maintenance light? No change, I’m selling it anyways.”
    orenji likes this.
  16. Mendel Leisk
    41,334
    ^ Some simple strategy. Getting a used car, it's best to assume past neglect, do a bit extra maintenance/inspection for the first while, then get back on the schedule. And bear in mind: all the maintenance intervals are miles or months, whichever comes first. For what it's worth: Canadian Prius don't have that maintenance light, and somehow we muddle through.
    Do you have the maintenance booklet? Google "Toyota Tech Info", input the car info in the "Manuals" tab, and you can google a pdf. Even if you have the physical booklet, the pdf is very handy. And then: read through it.
    Just take it to any old place? Maybe yes, maybe no. It's hard to generalize. Are you interested in DIY'ing some of it?
    Here's a summary of the US schedule. The aforementioned booklet lists maintenance event by event only. Converted to graph format, it's easier to read. Beside what's listed, I would also consider transaxle fluid change, and brake fluid change. Do note: I've just transcribed the schedule as presented in the booklet, am making no judgements about the importance of some items (checking driver's floor mat, for example...), or revising it any way:
    Also attached, some of the basic maintenance instructions.
    #16 Mendel Leisk, May 18, 2019
    Prieth, Bay Stater, RMB and 2 others like this.
  17. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    There is a sticker that states an oil change sometime in 2018. I can't recall the month right now. I am thinking about just taking it to my mechanic and having him just check everything out and do an oil change so I will at least have that info and whatever else he does or doesn't find wrong with it. One of the main reasons I bought a Prius was because it's one of the cheapest cars to own so I'm thinking since the car only has 38,000 miles, it's probably nothing expensive.
  18. Mendel Leisk
    41,334
    Check the dipstick, see how it looks, for starters. Prius oil tends to stay very clean looking, but just to get a feel for it's condition.
  19. orenji
    orenji Senior Member
    5,887
    3,488
    Don't be cheap on your new investment, change the oil, and don't follow the 10,000 mile oil changes, change the oil every time the maintenance reminder comes on. Also, if you don't reset the reminder it will remind you by saying service do now.
    Prieth, Bay Stater and Grit like this.
  20. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Some people ignore or wait on maintenance service and it became the most frustrating and expensive car ever owned. Get acclimated to EGR circuit cleaning and catch can install soon.
