Aftermarket backup Camera Reverse trigger wire
Discussion in 'Gen 2 Prius Audio and Electronics' started by 3prongpaul, May 17, 2019.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    If you need +12V when car is ONLY in reverse for your aftermarket radio/camera, this is where you can tap into it on a 2005 Gen2 in the front kickpanel. (likely the same on other G2's)
    Red wire in drivers kick panel area.
    #1 3prongpaul, May 17, 2019
    Dan_SLC, ydpplqbd and Prodigyplace like this.
  2. bobodaclown
    bobodaclown Member
    216
    72
    It's also behind the mfd in the center panel.
    SkyWolf and MSF1344 like this.
  3. SkyWolf
    SkyWolf New Member
    Kirkland, WA
    Would you happen to have any pics or diagrams of where it would be behind the MFD? Thank you.
  4. bobodaclown
    bobodaclown Member
    216
    72
    Sorry nope. Used wiring diagram found one the site. That's how I'm powering mine.
  5. 3prongpaul
    956
    730
    2005 never had backup camera from the factory so I don't think there's a wire behind the MFD like 2006-2009 would have.
