strange white substance on carpet in back seat
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bmparent, May 18, 2019.
  1. bmparent
    bmparent Member
    159
    65
    barre ma
    So I've noticed this white powdery stuff around the floor in the back seat. It's been there for a while, I didn't pay much attention because I thought I must have spilled some flour or something (I bake a lot). But I can see not that it's not flour but something more like a mold. The carpet is never wet. It's very fine and powdery almost like what you get around a better terminal when they're corrosion. That's what's coming to mind. Pics attached! IMG_2741.JPG IMG_2742.JPG
  2. Mendel Leisk
    41,743
    Ever get the interior professionally cleaned? Maybe some solution they used in past, didn't properly extract? Have you owned the car since new?
  3. cyberpriusII
    1,157
    1,820
    Mars Hotel
    Looks to me a bit like what happens when foam (as in used in seat cushions) starts to breakdown. Looks to be in the right place for it, also.
    Of course, if you -- whoops -- not going to say it. :cautious:
    Kris
  4. bmparent
    bmparent Member
    159
    65
    barre ma
    Never had it professionally cleaned (but it really does need it!) I've had it 5 out of the 12 years it been around.
  5. Mendel Leisk
    41,743
    Might be some action by the past owner(s) then, hard to say. Think I'd pull the carpet up and check below, especially around this:
    Looks odd.
    Or, might be that's where aforementioned desintegrating seat cushion is leaking down.
    What does it feel like, what texture? Crystalline, for example? A little foolhardy, but taste it? Then rinse out with copious water, lol.
    landspeed likes this.
  6. bisco
    52,185
    looks like that effervescence that comes up from my garage floor
  7. Patrick Wong
    18,210
    6,511
    I suggest you vacuum all debris and see if it returns.
    Montgomery and Mendel Leisk like this.
  8. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Whatever it is, it doesn't look safe. Vacuum it up, and like Patrick Wong suggests, see if it returns.
  9. bmparent
    bmparent Member
    159
    65
    barre ma
    dude your a genius. How come I didn't think of that! No really, I didn't even.
  10. bmparent
    bmparent Member
    159
    65
    barre ma
    Yea, they'll be no taste-testing here.
    bisco and Mendel Leisk like this.
  11. landspeed
    landspeed Active Member
    361
    209
    NZ
    2003 Prius
    I would definitely check the interface between that metal bracket, the floor of the car, and the bolt that is holding it in place. In case something electrolytic is going on, as that would be a bad place for corrosion!
