Shuddering issue at certain speeds
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Noah44, May 17, 2019.
  1. Noah44
    Noah44 New Member
    Chicago
    Hey guys.
    I have a 2013 Toyota Prius gen3. I had a fuel/air ratio imbalance light come on along with cylinder 4 misfire. I was shuddering pretty violently at 45 mph and about 65 mph on deceleration. Since then I have gotten a tune up and a new O2 sensor. It is not shuddering as bad as before but still shuddering nonetheless. No change in coolant level and my oil isn’t milky. Where should I go from here? I am hoping it is nothing serious I have paid already $600 on this issue. Any input helps!
  2. Grit
    Grit Senior Member
    6,160
    4,064
    Wilkes Land
    You should go see the doctor.
    RMB and Mendel Leisk like this.
  3. Mendel Leisk
    38,952
    How many miles on it? Ever looked at the EGR system?
    Noah44 likes this.
  4. The Critic
    The Critic Resident Critic
    3,193
    2,322
    CA
    Find a way to test the injector for #3. An injector balance test is one method to try. But on this engine it is probably easier (and quicker) to swap the #3 injector with #4 and see if the fault follows.
    If that does not solve the issue, do a leakdown test on cyl#3.
    Noah44 and Raytheeagle like this.
  5. The Critic
    3,193
    2,322
    CA
    An EGR should never cause a single cylinder misfire, especially #3.
  6. Noah44
    Noah44 New Member
    Chicago
    176k. I actually have never gotten the EGR checked. That’s what everyone’s been saying I should do.
  7. Bhavesh
    Bhavesh New Member
    Nz
    Hi did you end up finding the issue?
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    Old thread.....but in the absence of any trouble lights and codes, I think it would be prudent to check the tires and wheel first.
    Could be just loose lugnuts.
  9. Bhavesh
    Bhavesh New Member
    Nz
    i already had the wheels checked and road force balanced
