Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Tideland Prius, Sep 28, 2018.
  1. poppie
    poppie Member
    35
    81
    Silsbee Texas
    I figure I just want to know if it works now, before I install it:cautious:. wishing I could actuate, to test it.
  2. spiralhelix
    spiralhelix Active Member
    255
    217
    Illinois
    It’s a pretty simple valve. Electrical current moves a magnet opening the valve. I’m just not sure if the computer reduces the voltage or it just gets a full 12v dc of course. So if your ambitious, you could apply 5v (usb charger), the. Step up to 9v, and lastly 12v. It’s just a simple winding, so polarity will matter, but shouldnt ruin anything. Mine is being shipped back from the cleaner otherwise I’d go test it for you.
    -Spiral
  3. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    But don’t mess it up cause it’s not cheap.
    DogDaze, Raytheeagle and Mendel Leisk like this.
  4. Mendel Leisk
    42,082
    I'm kinda glad those screws on the cover defeated me. You can clean it without disassemble, just coming at it from both ends.
    DogDaze likes this.
  5. spiralhelix
    255
    217
    Illinois
    huh, i didn't even think twice about those screws. Just stuck a screwdriver in and turned, no fighting with them at all. Since I ended up putting mine in a cleaning bath, pulling the electronics off was imperative. But, you're right, manually cleaning is easy and no need to pull the cover. But if you want to open and close the valve manually, the cover has to come off. Like I said, if i had it in my possession I'd test it, but it should be on it's way back from the cleaner as we speak.
    DogDaze and Mendel Leisk like this.
  6. poppie
    poppie Member
    35
    81
    Silsbee Texas
    thanks for all your comments, it helps knowing you have a support group in your corner to help fight this corporate pile of needed upgrades!
    I got the fuel line removed @ 10:30 or so (pic shows the tool I used. I borrowed it. It looks like the Lisle brand #34750. Now I feel I'm finally getting somewhere IN THESE WOODS, maybe more lost, we'll see by mid-night...
    Going to go pay for and order my intake man. o-ring, mines a little too squished. While I'm there, I think I'll waste a little time requesting the service manager print me out the testing procedures from the Toyota service manual, on that EGR. The connector has 6 terminals in it, & I agree with cnc97, that's too many for me to start guessing. Since I spent 4-5 hours it seems, running around buying 2 different sets of "fuel line disconnects", spending $30-$40, then had to borrow one. What's 30 more minutes while trying to get the correct test procedure and saving my $170?
    I have the motor slung with slight pressure applied, and ready to remove the transmission bolts. but it's been a while since I've nourished my body, so I'll finish off the rest of that subway from yesterday. Now I feel similar to "Joe" who didn't get paid by Taco Bell. "What is the Deal?"
  7. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    With everything disconnected and out of the way, the engine will be out in no time. It’s only 7-8 bolts holding it in.
    DogDaze likes this.
  8. spiralhelix
    255
    217
    Illinois
    Are you using a come-a-long connected to a rafter to lift the engine? If so, how will you move it out of the way and get the new one hovering? Not asking in a judgmental way, genuinely curious so I can do the same thing when I am ready to do mine.
  9. Mendel Leisk
    42,082
    The EGR Testing pdf (attached) might be what you need, and there's a couple of others, just in the neighbourhood. If you can think of anything else, just lemmee know, torque values or whatever.
    DogDaze likes this.
  10. Mendel Leisk
    42,082
    He's got the front wheels on dollies IIRC, gonna do a @Ragingfit on it I think: lift engine, then push car out of the way.
    DogDaze and spiralhelix like this.
  11. poppie
    poppie Member
    35
    81
    Silsbee Texas
    motor is out and on the floor:):):). seems like that may have been the "easy" part :(! sooooo much to do...
    ordered the gasket, service manager gave me the ohms measurements from the manual, and is also supposed to e-mail me the complete wiring diagram.
    spiralhelix, there is a pic of my set-up attached. I planned on just pushing the car from underneath the engine like ragingfit did, BUT my blocks, as large as they are, still wanted to try and roll over, THAT FREAKED ME OUT. The idea of the car plummeting to the floor...So use HUGE blocks that are ROUND..:)confused::confused:how ironic, the square blocks wanted to roll, but the round blocks would not roll:confused::confused:) Therefore, I had to adapt to my situation and quickly, but it wasn't pretty as documented with the pics attached.
    cnc97, I removed 9 bolts, I hope I didn't make another mistake....and it was quick even with the ex man left on, plenty of room, for me anyhow.
    mendel, thank you for the tech info, i'll look at it closer tomorrow when I mess with the EGR again.
  12. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    It’s been almost a year since I pulled mine. I couldn’t remember exactly how many eng to trans bolts there were.
    DogDaze likes this.
  13. poppie
    poppie Member
    35
    81
    Silsbee Texas
    CNC97, you and others are quite the pioneers of this swap, and I thank you sincerely! I am retiring for the night.
    DogDaze and Raytheeagle like this.
  14. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    Necessity is the mother of invention, as they say. I’m sure there are other ways to explain it, but that sums it up quite nicely.
    DogDaze likes this.
  15. spiralhelix
    255
    217
    Illinois
    Cool. Thanks for the pics. Kinda jelly of your garage beam with winch. I need that!!!
    After seeing the dolly on the front drivers wheel and then the block on the passenger side, makes sense now. The wood “ramp” was a nice backup though.
    -Spiral
    DogDaze likes this.
  16. spiralhelix
    255
    217
    Illinois
    Btw, here is how I got mine out of my truck. Guess I wasn’t as brilliant as I thought, but at least I impressed the Mrs.
    -Spiral
    DogDaze, SFO, Robert Holt and 3 others like this.
  17. Mendel Leisk
    42,082
    If you could slip the Prius tranxaxle into Neutral it'd help. A lot, lol.
    Hindsight: Maybe could have put the front wheels back on, raised the front with floor jack and put those wheel dollies just under the front wheels.
    DogDaze likes this.
  18. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    Pull the park lock actuator?
  19. poppie
    poppie Member
    35
    81
    Silsbee Texas
    "HOLY HOISTED ENGINES, BATMAN! ARE YOU BELIEVING WHAT I'M SEEING?"
    "YES ROBIN. IT'S SOME KIND OF CONTRAPTION THAT ONE COULD USE TO SIMPLY LIFT AN ENGINE FROM IT'S COMPARTMENT, BUT WITHOUT ALL THE HEADACHE FROM SCHEMING AND PLANNING TO ACHIEVE SUCH A SIMPLE TASK. IT'S BRILLIANT! OR MAYBE???? YES, IT'S MISCHIEVIOUS! QUICK ROBIN, TO THE BATCAVE!! WE MUST FIND & STOP WHATEVER VILLIAN HAS COME UP WITH THIS BEFORE IT IS MASS-PRODUCED AND 'CITIZENS' JUST BEGIN PULLING THEIR OWN ENGINES WITHOUT THE STRESS OF IT ALL...."
    "YOU'RE RIGHT BATMAN, BUT HOW?"
    "I DON'T KNOW ROBIN. I DON'T KNOW!!!"
    "WILL THE DINAMIC DUO BE ABLE TO PROTECT CITIZENS LIKE POPPIE AND SO MANY OTHERS FROM SIMPLY, LIFTING & ROLLING THEIR ENGINE ACROSS THE FLOOR OF THEIR OWN GARAGES? TUNE IN NEXT TIME! SAME BAT-TIME, SAME BAT-CHANNEL!"
  20. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Nice job.
    This is almost the same engine you get in a corolla 2010.
    DogDaze likes this.
