Question on the egr cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by paphillyman, May 20, 2019.
  1. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    I plan on using a pressure washer to clean the EGR cooler and valve , my question is does the cooler and valve have to be dry before putting it back on ?
    seahawkguy, mjoo and Raytheeagle like this.
  2. Mendel Leisk
    41,234
    I would say yeah, just to be be on safe side. It's very easy to get it dry; a few minutes with a heat gun or hair dryer.
    I think I just shook things off and let them sit overnight.
  3. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    ok thanks , plan on doing it tomorrow , already took off the windshield wipers and the plastic cover and and the rest of the stuff to get access to the bolts
    RMB, Raytheeagle and Mendel Leisk like this.
  4. Mendel Leisk
    41,234
    Don't forget: drain a couple of quarts of coolant from the radiator drain spigot, into a clean container, and the EGR will be high and dry. Pour it back into the reservoir after, and leave one topmost coolant hose ajar, when pouring it back, hopefully will help it vent. I did that and it went well, no problems.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    It’s easy to dry;).
    A hair dryer works, or an air compressor works well:).
    Good luck tomorrow (y).
    RMB and Mendel Leisk like this.
  6. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    ok thanks guys , got my car up on ramps , going to drain some coolant now , will report back
    Raytheeagle likes this.
  7. Mendel Leisk
    41,234
    Do you have floor jack and safety stands, or no? My preference would be to have the engine underpanel removed, and the car back down on the ground, for most of this job (sometimes you do need it raised, for the rear cooler bolts). The engine panel off because sooner or later you'll drop something, and with the panel off, there's an even chance whatever's dropped will go all the way down to the ground. Maybe. And, with the car up on ramps before you start (as opposed to safety stands), you're stuck with that, since you can't start the engine to roll it off the ramps, and that 8" or so lift is going to make it like working on a Honda Pilot: you'll need to be up on a stool to reach anything.
    I might be overreacting, it's early. I did the job with the car on safety stands for the duration, and I just recall it was a reach a lot of times. Ah maybe all good, lol.
  8. mjoo
    mjoo Senior Member
    1,154
    1,326
    Michigan
    No. Exhaust is full of water vapor and the EGR cooler is one big distiller of that vapor. If you just let it drip out the residual water should make no difference.
    That's one reason why a PCV catch-can is necessary on a Prius to avoid the startup knock. There's an over abundance of water in the intake system between the PCV fumes and EGR water.
  9. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    Wow , what a pain in the !!@@##$$ , got it off though , had to take a break , power washer is next the hard to see bolt was the biggest pain
    Raytheeagle, orenji and Mendel Leisk like this.
  10. Mendel Leisk
    41,234
    Leave that nut off when reinstalling. (y)(y)(y)
    (I should have done that.)
  11. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    All done guys thanks for all the help especially NutzaboutBoltz Videos , I would of never done it without your guys help. I did also drain the engine coolant and refill it , used maintenance mode , going out for a test drive and going to get a cheesesteak !
    Everything checked out good , no CEL came on , no warning lights , and the best part I didn"t have any left over bolts when I was done !!
    #11 paphillyman, May 21, 2019
  12. Mendel Leisk
    41,234
    Intake manifold cleaning and Oil Catch can?
    After dinner, lol.
  13. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    all done , another NutsAboutBoltz video that got me through the mess !!! Did the OCC first , then clean the intake manifold a few weeks later
  14. Mendel Leisk
    41,234
    I did them in the same order. Save the "fun" one for last, lol.
    RMB and Raytheeagle like this.
