Fuel range
Discussion in 'Gen 3 Prius Fuel Economy' started by Triparadox, May 15, 2019.
  1. fuzzy1
    10,049
    If you aren't going to use the full amount of the tank (very understandable, because hardly anyone wants to get caught running out of fuel), then you simply can't expect to get the full range. That is just the way things work.
    49,003
    are we talking dte or actual range?
  3. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Which gas station do you go to? Not sure how that station passes inspections.
