800+ Mile Club
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 25, 2012.
  1. delayflight
    delayflight Junior Member
    Honolulu, Hawaii
    My car is not a plug-in. I do not use AC, always on Eco Mode, never use cruise control, plan my route to take advantage of battery by driving <41 MPH as much as possible, and I replace engine filter once a year.
  2. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    It’s real. Part of my commute goes onto a flat 20 mile stretch country road @ 41-43 mph which yields 75-80 mpg live real time readout on 2 sources. But I took everything but the spare tires & tools from the back out
    But the only real way to prove it for sure is images of the hsi readout and the # of gallons filled up at pump after the drive.
  3. delayflight
    Honolulu, Hawaii
    I am not as fortunate to have country roads. My drivings are all city with 50% freeway. I usually get skip several on ramps and get off several off ramps early if I have battery. I tried to completely use city streets but PG got worse due to many traffic light stop and go's.
    Here is my latest tank. Fulled 10.6 gallons, with up to 10% ethenol. 20190520_191215.jpg 20190520_191831_HDR.jpg
    James Powers, Maarten28, RMB and 2 others like this.
  4. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    That's pretty amazing. Even if it were a full tank.
  5. boywander
    boywander Junior Member
    37
    Washington
    It’s pretty much impossible for me to get results like delayflight. At best my average trip like the one below 62mpg.
  6. delayflight
    Honolulu, Hawaii
    Summer is here. I archived my personal best. I had a low tire pressure indicator early in the tank. Pumped tires to Toyota recommended 35 psi front and 33 psi back. I instantly got better MPG.
    Robert Holt, RMB and Mark57 like this.
  7. Mendel Leisk
    41,898
  8. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Good job!
    (Still no joy here as SWMBO doesn’t like the idea of driving around 32 straight hours at a steady 25 mph!)
  9. Mark57
    2,945
    2,740
    OK
    Hint, I did mine over multiple days in my 2010. Yeah you have the warm up penalty but that just makes a bigger challenge. :D
    (Mark57 (GenIII) 805.2 miles @ 79.3mpg)
    Robert Holt likes this.
