Car will not reverse.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RajivR74, May 23, 2019.
  1. RajivR74
    RajivR74 Junior Member
    37
    Horn Lake, MS
    The car goes into forward & reverse gears but won't move in reverse. 'Check hybrid system' is on the display & I'm getting trouble codes p0a40 & p0a41. These codes were there before but the car was driving normally after clearing them. Any help would be greatly appreciated!
  2. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    I'm guessing the electric motors won't operate. Driving in reverse is done electric only.
    P0A40 - Drive Motor 'A' Position Sensor Circuit Range/Performance
    P0A41 - Drive Motor 'A' Position Sensor Circuit Low
    Possible causes:
    - Faulty Inverter with converter assembly
    - Faulty Hybrid vehicle generator assembly
    - Faulty Hybrid vehicle motor assembly
    - Wire harness or connector
    I'd say: take it to a Toyota shop to have it fixed.
  3. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    If you're comfortable, check on the transmission system, just below the air filter box.
    In some cars, the sensor might be positioned on top the transmission, or built inside it.
    If its built inside, replacing the transmission system is the solution.
    You could also check to see of rats have eaten any of the wire harness there.
    RajivR74 likes this.
  4. ChapmanF
    17,999
    The motor "position sensors", a/k/a resolvers, are located inside the transmission. You can see them and their theory of operation in Prof. Kelly's videos from Weber State University.
    But there's pretty much nothing to go wrong with the resolvers themselves. Much more likely something has happened with the low-voltage electrical connections to the transmission (the normal-looking wiring, not the orange cables). Rodents would be one possibility.
    Fern1461 and RajivR74 like this.
  5. bisco
    51,784
    we're in gen 3 forum, is it the 2006?
  6. RajivR74
    37
    Horn Lake, MS
    No, it's a 2013.
  7. bisco
    51,784
    how many miles?
    have you owned since new?
  8. RajivR74
    37
    Horn Lake, MS
    It's got almost 360k miles on it. It's not my car. I'm trying to work on it for a friend who drives for Uber & Lyft. It's his sole source of income & I'm trying to help him as best as I can.
    Raytheeagle and bisco like this.
  9. RajivR74
    37
    Horn Lake, MS
    It won't move at all in any direction now. Just a bad shuddering sound. Similar to what was happening when the car was turned off before.
  10. bisco
    51,784
    try the online service manual. are you reading codes with tech stream?
  11. RajivR74
    37
    Horn Lake, MS
    No. I'm reading them with the torque app on my phone paired to a very basic Bluetooth OBDII reader.
  12. RajivR74
    37
    Horn Lake, MS
    Where would I find the online service manual? Do you have a link to it?
  13. bisco
    51,784
    if you exhaust the possibilities laid out above without any luck, that might have to be the next step.
  14. bisco
    51,784
    techinfo.toyota.com
  15. RajivR74
    37
    Horn Lake, MS
    Thank you. I'm checking it now.
  16. Mendel Leisk
    41,215
    That is a lot! Has it been just basic maintenance up to know, mostly oil changes? It would be a minor miracle if the EGR is still functional.
    Guessing inverter coolant pump failure caused transaxle to burn out?
    I'll pm you a link.
  17. RajivR74
    37
    Horn Lake, MS
    Yes, please. That would be great. Thank you very much!
  18. RajivR74
    37
    Horn Lake, MS
    Ok. I have no idea what happened but the car is operating normally now! All I did was let it sit for a couple of hours, turn it on & immediately shift into neutral to avoid the loud shuddering (almost grinding) noises. The ICE was charging the battery like it should. I cleared the trouble codes (P0a40 & P0a41), turned the car off & restarted it. It now drives forward & reverses like nothing was wrong with it! I have only done this in my driveway as I am afraid to take it out on the street. What do you guys think?
    pattle likes this.
  19. bisco
    51,784
    could be what mendel said above. without the coolant pump working, the car will keep shutting down when it gets too hot
    RajivR74 and Mendel Leisk like this.
  20. ChapmanF
    17,999
