JDM style DRL
Discussion in 'Prime Accessories and Modifications' started by JspecPrime, May 19, 2019.
  1. JspecPrime
    JspecPrime Member
    68
    37
    L.A.
    2018 Prius Prime
    I think it looks pretty good, should look better after I install my grill and front lip. 20190519_183504.jpeg
  2. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    Nice. Did u get the 45cm or the 60cm version? And can you provide a few close up shot without fire up the led stripe?
    iPhone ?
  3. JspecPrime
    JspecPrime Member
    68
    37
    L.A.
    2018 Prius Prime
    yoyoman likes this.
  4. Flaming
    Flaming Active Member
    138
    123
    QC , Canada
    Technology
    link ? where to buy ?
  5. JspecPrime
    JspecPrime Member
    68
    37
    L.A.
    2018 Prius Prime
    Flaming likes this.
  6. yoyoman
    342
    117
    San Jose California
    Got mine last week from TW. And I made a video showing my Prime new looks. :)
    iPhone ?
  7. GTprii
    GTprii Junior Member
    27
    Bay Area Cali
    how does it look like?
    yoyoman likes this.
  8. yoyoman
    342
    117
    San Jose California
    iPhone ?
    Prius from Dad likes this.
  9. Jessecee
    Jessecee Junior Member
    Los Angeles
  10. yoyoman
    342
    117
    San Jose California
    You should be able to find similar under eBay. Try search eBay for “Headlight DRL Turning Light”.
    iPhone ?
    GTprii likes this.
  11. Tacongcohan
    Tacongcohan New Member
    Huntington Beach, California
    2019 Prius
    Two Eco
    Question, is the headlight plug is the same on the Prime as the regular Prius? I got a 2019 Prius LE, the plug has the same green wire that supposedly for the blinker. I'm trying to do the sequential DRL like yours as well, I'm just not sure which to wire it to.
  12. yoyoman
    342
    117
    San Jose California
    I did not wire my DRL into my head light- only DRL main line to my fuse box and DRL signal line into my prime signal connector 12+. As long as you can identify the +12v line from the headline connector, you sb fine.
    iPhone ?
    #12 yoyoman, Sep 27, 2019
  13. Tacongcohan
    2019 Prius
    Two Eco
    Oh no no! I know what you mean, I'm not wiring it into the headlight either. It's the plug (see picture). You wired it into the plug as shown in the picture, yeah? Green wire for the blinker? Yes? What I'm concern about is if the plug on your prime is the same as the plug on my LE. I'd really hate cutting into the wrong wire lol.
    Sezy likes this.
  14. Sezy
    Sezy Active Member
    443
    231
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Did some mock testing on mine last night. Limited trim with fog lights. Going to grab a volt meter & see what wires have power coming off the turn signal harness. Snapchat-845631858.jpeg 20200309_212629.jpeg
    tezza.rae and yoyoman like this.
  15. Sezy
    Sezy Active Member
    443
    231
    37
    2020 Prius Prime
    Originally I tapped directly into the turn signal/DRL plug. Worked great with testing just the flashers but using the turn signal it would blink once then nothing ,not even in the dash. Found out the lights need power to the white running lights to use the turn signal. Since I tapped into the DRL for that I'd have to have it on so did some testing and added a blocking diode on both blinker power lines. It worked, the turn signal works without needing the white DRL power.
    Months later when doing another project I remove the white DRL from the plug & ran it into the cabin with a switch to a fuse tap. So now my white lights come on with the car & can toggle them off.
    Only had one issue since where the white running lights were on & one started flashing orange then remained orange until powering off & back on.
    20200608_224521.jpeg 20200414_143702.jpeg 20200409_185949.jpeg 20200701_110922.jpeg 20200701_110930.jpeg 20200701_110937.jpeg 20200701_110948.jpeg 20200701_110959.jpeg 20200701_111010.jpeg
    chickenhawk and yoyoman like this.
  16. chickenhawk
    chickenhawk Member
    261
    96
    CA
    Looks great if I add any more lights to my car it's gonna be UFO:cool: but I might do it anyways :ROFLMAO:
