Dealership pulled up a stored C1202 code during a pre purchase inspection
Discussion in 'Gen 3 Prius Main Forum' started by mattbatson, May 16, 2019.
  1. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    What are the signs that the car could’ve been driven recklessly?
    mjoo likes this.
  2. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    I'm going to give my opinion...and just know it is my opinion only ;)
    I think that when you come onto one of these specific car make forums and start reading, that you really only see the people who own your car make/model who have problems with the car.
    People come on here to post about issues, or to complain when something goes wrong...etc...
    People who own and drive your specific make/model, who do not have any problems during their ownership...don't come on here to post.
    So, as a result, it gives some the impression that their specific make/model of car is unreliable and will burst into flames at any given moment ;)
    I've been on car forums, of various types, since the internet took off in the nineties. I've owned a lot of different types of cars, and worked on all of them myself...and I can say that this phenomenon spans across all forums on the internet that are based around a make/model of car.
    That said, I will probably pull the egr cooler to clean after purchasing this car. I will report up on the condition of the cooler when I do that. Probably check the spark plugs at the same time.
    among other things...
    And plan on having a car that will run and run and run for another 200k miles ;)
    jb in NE, Bay Stater, royrose and 2 others like this.
  3. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    With all of that said I will say that Prius chat has been invaluable to me and has saved me probably thousands of dollars and I am eternally grateful for the people who take the time to come on here and educate the rest of us on the Prius
    Bay Stater, ETC(SS), Prieth and 3 others like this.
  4. spiralhelix
    spiralhelix Active Member
    255
    217
    Illinois
    I'm certainly not going to argue with this sentiment. You are totally right. There are a heck of a lot more Prii owners out there than there are on this site. There are also a heck of a lot of Prii owners that just trade-in the car at the first thought of an issue. IMO, the telling thing is that YES a forum will uncover the most common problems the more people post about them. And YES all cars have problems that come to light once people post about them, IE. Ford Sport tracs are notorious for having transmission solenoid issues...i know first hand ;). My take away is if the problem is something I'm willing to work with or are there other options available with maybe easier issues to deal with. I don't have a Prius, but it's cousin the CT and there are only a handful of people on that forum that talk about the EGR. So does that mean the CT doesn't have the same issue?? nope, it most certainly does suffer the same fate. Also, do you really think a dealer is gonna tell you what problems to expect as the car ages? yeah right! Lexus: "We have NEVER heard of a CT that needed a new engine" . Me: <reading priuschat.com after an engine replacement and seeing 104 posts relating to the exact symptoms we had>
    Now, just to complicate the point, we had a sunroof explode on the CT and I haven't read other CT owners with the same problem...but I have read plenty of sunroof owners but different manufactures with the same problem (all in close year manufacture dates). They all used the same glass company from what i've found.
    I guess my point is that coming here and seeing lots of post about EGR says I should pay close attention to that system whereas my other issue I just have to chalk up my sunroof to bad luck or the guys that made the glass went out drinking the night before.
  5. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    Two things are certain in life, death and EGR clogging with a 2010-2015 Prius. After pulling mine and seeing how clogged
    After 120,000, I must have had luck on
    my side. Completely clogged, no doubt head gasket would have blown within another 10,000-15,000 miles. It’s a pain to clean but it’s either that or throw money out window what you paid for the car. It will happen, just a matter of when if not cleaned.
    Bay Stater, cnc97 and RMB like this.
  6. spiralhelix
    255
    217
    Illinois
    bwahahahahahahahahahahahah! :LOL::LOL::LOL::LOL::LOL::LOL::LOL::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
    Bay Stater, Borninblue and RMB like this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Having worked on a CT before, I can tell you the Egr circuit clogs just as badly as the Prius ;).
    Being as though theemgine is the same, not altogether surprising :cool:.
    But definitely present (y).
    Bay Stater and RMB like this.
  8. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    This is an extreme example of what “can” happen when the head gasket lets go.
    When I tore down the engine after the fact, I found a second rod broken, in addition to piston shrapnel from where the number one piston exploded inside the block.
    Between number one and two is where my head gasket let go.
    Bay Stater and Raytheeagle like this.
  9. Brandon_P
    Brandon_P Junior Member
    US
    I have a 2010. Bought it with 45k miles. It just hit 145k. I bought this car because I drive 250 miles a day and get paid mileage and thought it would save me money. So far it has been a money pit.
    48k milesnew headlight bulbs
    50k miles new headlight bulbs
    51k miles new headlight bulbs
    52k miles new headlight bulbs
    Toyota finally "recalled" wiring harness. Still doesn't have the "parts" at my dealer to fix. I replaced headlight bulbs with LEDs so far no more failures.
    At 110k the head gasket failed.
    Rebuilt engine: $3600
    1st rebuilt engine through a rod because the oil pump failed, replaced under warranty.
    Soon the battery will need to be replaced around $2500.
    So unless you have about 6k to put back into it, RUN AWAY NOW buy a cheap beater your return on investment will be much better!!!!
    SM-N960U ?
    Grit likes this.
  10. spiralhelix
    255
    217
    Illinois
    so over on clublexus I was having a discussion about headlights. Though I "conceded" to his argument, I still have yet to understand why LED replacements are soooo bad. I was having the same issues as you with constantly replacing headlights and picked up and LED kit and they have been working flawlessly for over 2 years. I wondered if there was a wiring issue, but after examining a package and seeing that headlights only last between 270-400 hours, it really isn't uncommon to replace headlights if you do a lot of night driving. In the city you may only be driving for 20-30 min, on the highway, not hard to rack up 200+ hours, especially during the winter with dark morning driving too. But if there is a recall on the wiring, do you happen to have a link to the recall?
    Unfortuantely, HG failures are becoming more common if you read through any thread discussing the EGR system/cooler clogging. I would agree it's hard to stomach a large repair bill, but I bet you have already realized some savings since first taking possession. To be safe, since you are driving that many miles (assuming highway which means more ICE usage) definitely check out the EGR stuff and keep it cleaned. Your Prius has hundreds of thousands of miles left in it.
    The price for the HV battery is a bit on the high side. Member @2k1Toaster sells batteries and if you read enough threads on this subject you will see his do well. His site is: newpriusbatteries.com
    Even at a high price of $2.5k, that battery has lasted 9 years (if it dies tomorrow), so that's a pretty good track record for a battery.
    getting "value" out of a car is a pretty big gamble no matter how you look at it. I could get that beater and it could die within the first week. The overall maintenance costs of a prius are actually quite low. Oil changes, tires, fluids, brakes; all have to be done no matter what car you get. All cars are also prone to having it's own "expensive repairs". We had to /replace/ our engine, but the savings in fuel and other expenses still show our yearly/mileage cost of ownership to be lower than the previous vehicle we were driving (matrix).
    I hope for many more miles for you on your Prius!
    Bay Stater likes this.
  11. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    I hear you guys
    But
    My friend has a 2010 with 230 k miles on it
    With much of that being long distance trips on the reg to visit family
    Never had the egr touched
    I suppose death is unavoidable though. ;)
  12. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    At 230k miles, the EGR just hasn’t been touched YET. My car had 209k on it when I bought it last year. Guy drove it 80 miles one way to work for like 6 or 7 years. Plus back and forth from PCB to Louisville KY twice a year. At 213k, the HG popped and grenaded the motor. The EGR cooler was 99% stopped up.
  13. spiralhelix
    255
    217
    Illinois
    Yeah I was thinking the same thing. Some people have problems at 120k, 150k, I lasted until 203k. And it wasn’t like a slowly progressing issue. It was one day ran great, next week rough start, midweek bucked at stoplights, engine dead on Friday.
    I’d say your buddy is on borrowed time. If he pulls his cooler and can see through it I will be floored.
    -Spiral
  14. Borninblue
    233
    158
    Cleveland, Ohio
    That’s fine, but with anything there are exceptions. Your friend’s rare to not have the head blown yet. I guarantee to you there is a very little to no air path in that cooler. To just believe it doesn’t apply to some vehicles is not accurate.
  15. Grit
    Grit Senior Member
    6,414
    4,182
    Wilkes Land
    Italian tune up, our friend Bill Norton would vouch.
  16. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    I think that some of the people on here are here because they blew a head gasket
    Head gasket goes...then they go online
    find this forum
    sign up and post about their blown head gasket
    what I would like to know is ...how many people on this forum , did not come on here because of a blown head gasket
    but have just been on here because they’re Prius owners...or maybe had a different issue and signed up... how many of that group have a blown head gasket?
  17. spiralhelix
    255
    217
    Illinois
    i guess technically I didn't come here because of a blown head gasket, I came here from clublexus after a full engine replacement and was told bent rod (didn't even talk about HG). But really, the EGR was already on the radar because I googled the symptoms we were having. So only make sense: person has car issues, googles symptoms, prius chat thread top result, read through, sign up, add case to the ongoing discussion. rinse repeat.
  18. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    I started here with our 2010 and shared about the egr circuit cleanse that I had done ;).
    Sold the car at 200 k miles and the head gasket was still in tact(y).
  19. spiralhelix
    255
    217
    Illinois
    Thinking about it some more, on the club Lexus ct forum, yes egr is discussed, but that group would not be a good pool of data regarding HG issues. Someone once said though that far fewer CTs were sold compared to Prii, and the demographic for the CT is less likely to drive them like a Prii. So you see less “high mileage” discussions compared to over here or the demographic is less likely to be on forums, they will most likely just take it straight to the dealer no questions asked.
    -Spiral
  20. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    I used to hang out at club Lexus in the rx forum, but that crowd was rather dry:cool:.
    I worked on a ct200h a couple of meetups back that had 159 k miles on it. Did the egr circuit cleanse :).
    Might have just caught it prior to the head gasket failure, but we’ll never know now as a deer totaled out @SacLexToy ’s beautiful red ct:(.
    Bay Stater and spiralhelix like this.
