Hill Holder?
Discussion in 'Gen 2 Prius Main Forum' started by zoomx7, Sep 2, 2006.
  1. zoomx7
    zoomx7 New Member
    22
    I thought I saw a Toyota fact sheet that stated the Prius has a "Hill Holder" mode that will keep the Prius stopped on an incline when you let your foot off the brake (so it doesn't roll backwards).
    I haven't noticed this in my car, but I haven't tested it fully yet.
    Anyone familiar with this?
    Thanks
    mfc
  2. Tideland Prius
    16,602
    Yeah, it's listed as a feature on Toyota Canada's site too. I think they might be referring to the "creep" that's built into the car so that the car doesn't roll back on slight inclines as it does on cars with manual transmissions. I don't think they were planning to have a "real" hill hold feature (à la 4Runner) in the first place.
  3. qbee42
    3,079
    It's just the creep built into the HSD system, which makes it feel like a "normal" automatic transmission. There is no need for a hill holder of the type sometimes used with manual transmissions.
  4. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Hill-holding is basically increasing the creep force fairly
    dramatically if the system detects that the car is rolling a
    little in the direction *opposite* the one intended. To get an
    idea of how this works, try shifting into "D" while slowly rolling
    backwards -- you'll feel a large pulse of torque that stops the
    car, and then it'll start creeping forward normally with less force.
    _H*
  5. marjam
    marjam Member
    220
    Silver Spring, MD
    I agree, too, that it is the faux automatic transmission feel. I don't know if I like the idea of there being a "creep" in my car though, unless it is me!
  6. darelldd
    6,059
    389
    Northern CA
    Hobbit's got it, as usual. Yes, it is there, and yes it is beyond the normal "creep." I drive on the SF hills somewhat regularly, and you can most definitely feel this "feature" when you're stopped with your nose way up in the air, and you take your foot off the brake. I sure don't need it - but it is there. It is somewhat of a shuddery experience to use for any length of time.
  7. zoomx7
    zoomx7 New Member
    22
    Thanks All.
  8. Mary Snyder
    Mary Snyder New Member
    132
    <div class='quotetop'>QUOTE(darelldd @ Sep 3 2006, 04:23 PM) [snapback]313565[/snapback]</div>
    Darelidd,
    Could you please explain the Hillhold feature and also do you use it? Or are you afraid to use it. I can't really tell by your post.
    sincerely,
    Mary
    <div class='quotetop'>QUOTE(MyTFineCar @ Sep 2 2006, 11:41 PM) [snapback]313339[/snapback]</div>
    MyTFineCar,
    How do you put the car in "Hill Holder" mode? I would love to know this.
    Sincerely,
    Mary
  9. Tideland Prius
    16,602
    As I've mentioned before, it's a typo. It doesn't have a "true" hillholder function (i.e. the one where if you let go of your brake pedal, the car still has the brakes applied for a few seconds until you press the accelerator or that few seconds expires).
    It has a built-in creep function to mimic an automatic transmission.
  10. Mary Snyder
    132
    <div class='quotetop'>QUOTE(Tideland Prius @ Dec 3 2006, 02:32 PM) [snapback]357014[/snapback]</div>
    Thanks Tideland,
    That's much clearer, but should I or should I not hold down the brake pedal at the crest of this slight incline? If I have my foot off the brake while waiting for the light to change what would happen? Thanks.
    Sincerely,
    Mary
  11. Tideland Prius
    16,602
    <div class='quotetop'>QUOTE(Masnyd @ Dec 3 2006, 10:41 AM) [snapback]357020[/snapback]</div>
    Hold the brake pedal. This does not have the automatic brake HOLD feature that debuted on the new LS460. Depending on how steep this incline is, it may or may not roll back (like any ordinary car with an automatic transmission0.
