Owners Of The Duosida L2 EVSE
Discussion in 'Prime Main Forum (2017-2022)' started by Rob43, Jun 3, 2019.
  1. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    For those of you that own a Duosida EVSE unit, how well does your male charging handle fit into the charging port of your Prime ?
    Is it perfect like the OE Toyota EVSE unit, or is tight fitting ?
    Rob43
    52,337
    my aftermarket evse (white handle) has always been tighter than the oem
  3. KCWhitney
    KCWhitney Active Member
    140
    118
    Connecticut
    2025 Prius Plug-in
    It's a tight fit.. When I first tried to unplug for the first time, it I thought it was locked in. It just takes effort and a little wiggling.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Very tight. I've used dielectric grease, but still pull with both hands to make sure I'm pulling it straight out.
  5. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    Mine was a bit tight at first, like many new items. After a month or so of use, it's not that bad.
    Mines not duodisa, but I'm fairly sure it shares the same white connector
  6. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Ok, thanks to all that responded.
    That's what I figured based on my experience with the Chinese made L2 EVSE unit I was testing, my charge handle was unacceptably tight.
    Rob43
    #6 Rob43, Jun 9, 2019
