Carpool lane dilemma
Discussion in 'Prime Main Forum (2017-2022)' started by skierrob, Jun 6, 2019.
  1. skierrob
    skierrob Member
    39
    signal hill, ca
    2019 Prius Prime
    I live in Long Beach, CA and commute every day to Pasadena. For the longest time I’ve driven up the 710 (which has no carpool lane) to its end in Alhambra and then taken surface streets to work. The distance is about 29 miles which means I can get to and from work on electrical alone without having to use gas. In traffic, I normally get between 28 and 32 miles of electrical on a charge thanks to slow speeds and regen braking.
    But then my carpool stickers arrived. And Waze showed me I can take the 605 to the 210 west instead using carpool lanes — and that doing so would save me between 10 and 15 minutes of time each direction!
    But the new time saving route is 43 miles long - an 11 mile increase. Odd how things work in Los Angeles in terms of traffic, right??
    So now I have to make a decision. Do I take the longer, but faster route and use some gas every day? Or do I take the slower, shorter route to only use electricity?
    Note that I charge for free at home (the complex lets me plug into a 110 outlet at no charge), and I pay about $1.50 a day to charge at work.
    What would you do given the same choice? I’m conflicted - my time is worth a lot to me, and sitting in less traffic is awesome ... but I also hate burning / wasting gas lol!
  2. Mendel Leisk
    41,947
    I'll vote lower speed and shorter.
  3. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    I second that! Enjoy listening to audio books or your favorite music with the extra time you have in your car.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I have a similar problem, I have a Prius v that gets 38 MPG the way I drive it, and I pay for the gas. My wife has a company Tahoe that gets about 17 MPG the way I drive it and her employer pays for the gas.
    Do I drive to use fewer resources or to save money? I drive to use fewer resources, and take the Prius, not the anti-Prius.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    How much is gas down there?
    Time is the most precious resource we have, and you can never get time back;).
    As someone who does 38 miles one way up here in the Bay Area, if I could find a shorter time route, I’d take it (even for 11 minutes) as it would allow more time for things I want to do, not need to do:cool:.
    Use some gas and save some time(y).
    noonm and jerrymildred like this.
  6. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I would take the shorter route and accumulate fewer miles on the car. Listen to an audiobook or podcast so the extra time is not wasted. The option always exists to take the fast way if you need to be home earlier.
    Mendel Leisk and Prius from Dad like this.
  7. bisco
    52,417
    how long does your current drive take?
    i would test the other route, for awhile before deciding on the best course
    pghyndman likes this.
  8. ETC(SS)
    7,379
    Surface streets are harder on cars than freeway driving.
    More regenerative braking means.....more braking, and there's a time penalty.
    Your chances of an accident are greater on surface streets. Also even in California, in some cases the cost of non-free charging is sometimes > than gas driving....so a split decision might work better for you, meaning drive TO work on the "free" juice that you get from your apartment and put the $1.50 a day into a piggy bank, unless it makes more sense not to.
    My last fill-up was $2.11 a gallon, so I already know how the math works for ME.
    As pointed out earlier, TIME would be the overarching factor for ME.
    As long as you live in an area that allows HOV access for single occupancy gas burners, I'd take advantage of that law!!!
    Every......time.
    Good Luck!
  9. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Having alternate route is good thing. If you are not in hurry, use car pool lane. All EV and no gas is a good thing. When you are in hurry use longer distance but shorter travel time route. That's all. ;)
    #9 Salamander_King, Jun 6, 2019
  10. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    You may not have driven on the freeways around LA recently. You use your brakes a lot on those freeways.
    utsug and ETC(SS) like this.
  11. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Another thought - try them both and see which is less stressful and how much time you are actually saving. Waze is generally pretty accurate, but not always. Or, just flip a coin each morning - heads you go one way, tails you go the other. Then each day is a surprise.
  12. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    First, I'd check the new route to see if it really saves you the time it says, and also judge the route for possible complications. Then I'd vote for saving the time, but it's going to cost you more money because of burning gas. It wont hurt the car any, it's designed for hybrid mode and it works pretty well that way. My time is pretty important to me too and burning 20 or so miles a day in gas is a small price to pay. (I actually have a 75 mile commute and can only charge at home, so I burn gas every day no matter what.)
  13. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Your last sentence would seal the deal for me. You're only using gas for 11 miles each way for less than a couple of bucks even at California prices.
    As others mentioned though, check out the WAZE route and see if it's good alternative for you.
  14. Leadfoot J. McCoalroller
    8,152
    7,654
    Pennsylvania
    2018 Prius c
    I guess it all depends on what you're going to do with the time savings. Race powerboats? Take a nap? Burn rainforests? Whatever it is, consider that vs. the time lost behind the wheel.
    Raytheeagle likes this.
  15. ETC(SS)
    7,379
    There are rain forests left to burn?
  16. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Pretty certain there are none of those in Southern California.
  17. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    I think I'd do whatever is less stressful. I wish there was a stress free route to my workplace. Or even a low stress one. :oops:
    Mark57 and Raytheeagle like this.
  18. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    When I was commuting 31 miles each way, on nice days I would take the convertible on the back roads and enjoy the scenery and fresh air. Otherwise I took a different route that was shorter and quicker, but not as nice.
  19. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Uber?
  20. jerrymildred
    11,517
    14,158
    Tampa, FL
    And add the stress of putting my life in the hands of one of those clowns choking the roads doing stupid stuff. And pay for the privilege on top of it. ROFLOL. I don't think so. :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO: There's only one driver I trust and I'm not totally sure about him. :)
