Just wanted to say thank you to everyone here.
Discussion in 'Gen 2 Prius Main Forum' started by Nik Marr, Jun 7, 2019.
  1. Nik Marr
    Nik Marr New Member
    Dallas TX
    We bought a 2005 Prius a few months ago for a pretty cheap deal knowing it would need a couple things (tie rod, mirror, small stuff). After making the repairs we discovered a horrible whining/humming noise.
    A few hours through Priuschat and I was able to diagnose it as a bad wheel bearing. I've never done anything like that. Called a shop and got quoted $1200. Decided to try it myself.
    Seriously you guys. I followed what people on these threads had said and was able to knock one side out in 1.5 hours. It was an amazing feeling.
    I was also able to do the rotors and brake pads simultaneously and again the threads here walked everything out step by step. Even dealing with the codes the dash threw up after.
    You are all amazing and those of you who have taken the time to write up detailed instructions and guides. I salute you.
  2. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Skibob likes this.
  3. bisco
    52,252
    congrats and welcome! all the best (y)
  4. MilkyWay
    MilkyWay Active Member
    823
    359
    MI
    Seems very high as you state it is 1 to 1.5 hours tops per side.
    My mechanic charges $100 for both and will include pads/rotors as well as they come off anyways.
    Other shops will pretend doing the brakes is a brand new job lol and charge an additional hour or 2 labor on top of the hour or 2 labor for wheel bearings.
    You must be very mechanically inclined cause it isn't easy changing them out.
  5. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    That much should get all four done...
  6. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    Congratulations on doing your own work...and saving money. ;)
    jb in NE likes this.
