Gen 1 to Gen 2
Discussion in 'Gen 2 Prius Technical Discussion' started by bigblock67, May 2, 2019.
  1. bigblock67
    bigblock67 433K with new cells
    171
    35
    Indiana
    2002 Prius
    Will a complete Gen 2 battery work in an 02, are the electric connections compatible? Is it a simple R&R ?
    edthefox5 likes this.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    No...
    Gen 2 HV batteries have only 28 modules. Gen 1 has 38 modules, The gen 1 case is significantly different. The cooling fan and ductwork arrangement is significantly different.
    No...............electrical connections are not compatible..........
    Some people have installed 38 Gen 2 modules into a Gen 1 case. The gen 2 modules are just slightly longer, but still fit in the case.
    SFO likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    Nice Vette.
    bigblock67 likes this.
  4. bigblock67
    171
    35
    Indiana
    2002 Prius
    That is good info. The higher voltage won’t create an issue? This car has 425 k mi. And I would like to save it since no other issues are present.
    Thanks
  5. TMR-JWAP
    6,404
    6,088
    Columbia, SC
    The Gen 1, 2 and 3 modules have identical ratings (voltage and capacity). Gen 2 and 3 are physically/dimensionally identical. The Gen 1 is the same width as the Gen 2 and 3, so a stack of 38 modules, regardless of Generation, will fit perfectly in your Gen 1 clamp. The only difference is the Gen 2/3 modules are slightly longer, but the underside mounting bolt holes will still match up. The Gen 2 and 3 use only one underside mount bolt per module instead of 2.
  6. edthefox5
    10,096
    4,832
    Clearwater, Florida
    I miss my 67 vette but it had no ac so couldn’t drive it but a few months a year and even then it sucked
    Never knew the cabin got so hot till I bought one
  7. bigblock67
    171
    35
    Indiana
    2002 Prius
    I had a 67 in 69. 427/390 with no options. Remember that AC was a luxury then and never cared that much about it. It was my only car then and just sucked it up. Now , I’m not climbing into if temp is north on 80
  8. bigblock67
    171
    35
    Indiana
    2002 Prius
    That’s great info .. do you have a recommendation to purchase a full set thinking of cost? Thanks
  9. edthefox5
    10,096
    4,832
    Clearwater, Florida
    I bought my 67 from a guy who had just installed a rebuilt 350 in it. He couldn't figure out why it would keep over heating. It would be ok on the highway but as soon as you stopped at a light the temp gauge would spike. I thought the motor was blown and his priced reflected that. It made it home though and I started looking at it.
    He had the fan blade on backwards. It was blowing instead of sucking. It was a joyous moment when I figured it out. When I would stand over the rad with motor running I was getting wind in my face...that's not right.....lol.
    Skibob and Raytheeagle like this.
