Dr. Prius HV Battery Test Results
Discussion in 'Gen 4 Prius Technical Discussion' started by Elt31987, Jun 7, 2019.
  1. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    If this app is remotely accurate then I'm a very happy owner. This is with 72K on the clock.
  2. pyrower
    pyrower New Member
    Fredericksburg, VA
    I also hope it’s accurate. Had similar results after 65000 miles.
    Have you used it while driving? My pack voltage frequently jumps to 220v and flashes red in the app. I hope my driving style, which is great for fuel efficiency, doesn’t kill my battery prematurely.
  3. Elt31987
    205
    155
    Derry, NH
    Yeah that was always my concern. I use the battery more than the average owner so I was thinking mine would fail before most owners. But hopefully this is true so I can hit my 250K mile goal
  4. Mendel Leisk
    41,645
    What bluetooth reader do you use? I've got the app, but need to get in gear and get something, lol.
  5. Elt31987
    205
    155
    Derry, NH
    Picked up the carista for 14 bucks on Amazon
    Pdaddy and Mendel Leisk like this.
  6. pyrower
    pyrower New Member
    Fredericksburg, VA
    I like Carista. That way I can also do things like turn off the annoying reverse beeping. 20$ or so.
    TGrracie and Mendel Leisk like this.
  7. Elt31987
    205
    155
    Derry, NH
    The Dr. Prius app will also shut off the back up beep and seat belt chime which was a nice extra.
    pyrower likes this.
  8. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I got 83% capacity on my 10 year old Prius with 96,000 miles. I am hopeful of a long battery life but I do wonder if some batteries drop precipitously at some point, especially now as I am not putting many miles on it.
    Hybrid assistant recommends the OBDLink LX which I have. It is not a cheapie, around $50 from Amazon, but it works well with both Hybrid Assistant and Dr. Prius
    Mendel Leisk and Elt31987 like this.
  9. Geo S.
    Geo S. Junior Member
    So.Cal.
    2019 Prius
    Could someone please direct me to the OBD port for my 2019 Prius Limited? I've purchased the OBD tool Carista, but cannot find the port. It's not in the same location as the 2016 or 2017 models. I've found a few video's on youtube, which show the location for the 2016, but it's not in the same place. Thank you.
  10. Elt31987
    205
    155
    Derry, NH
    I think every vehicle is somewhere right under the dashboard by your feet
  11. Geo S.
    So.Cal.
    2019 Prius
    Thanks you very much for replying. I appreciate it, and I suspect you are correct. However, not being tech savvy at all, I searched for over an hour yesterday; even pulled covers off the right side under the dash, but no luck. Still haven't been able to use my Carista.
  12. krmcg
    2,592
    2,392
    Whittier, CA
    under the dash close to where your knees reside...
