No radio, Smart Key or Dome lamps
Discussion in 'Gen 2 Prius Audio and Electronics' started by Knightrider, Mar 11, 2019.
  1. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    Checked underhood 15 amp and swapped w known good headlamp fuse-
    Checked under steering wheel 7.5 ACC fuse and is good- swapped w known good fuse.
    I have no radio- Dome lamps or smart key functions.
    Note- these did work before car was sitting for 6 months.
    Charged 12v battery at 1amp to bring to 14-
    Currently 12.86
    hv was rebuilt and balanced - and car has lost all but vsc warning lamp .
    Ideas?
    #1 Knightrider, Mar 11, 2019
    52,001
    i could be wrong, but i thought dome was 10a (n)
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Bad connection at one of the main battery cable connection points.
    If you have "jump points" away from the actual battery, check the voltage there when you get it as close to "ready" as possible.
    Was the 12.8 measured when it was "on" ??
  4. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    I will look to see what I get
    Seems strange to have nothing functional —-
  5. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    Battery checks at 12.5 w headlamps on and also- replaced ACC 7.5 and underhood 15 Dome fuse w new.
    No change.
    Think the radio has a fuse on rear like aftermarket?
    Any ideas.
  6. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    IS there a fuseable link on the 12v battery that could be bad? Or underhood- the large link is all intact-
  7. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    So I have checked main battery 120 a fuse and 5 amp fuse and also disconnected and reconnected positive and ground-
    I get 12.5 volts at jump terminal resting - 12.8 starting-
    I am at a loss.
    I will go and replace all interior fuses in cabin box -
    I did some relay switching thinking maybe one was stuck-
    Any ideas ????
  8. padroo
    padroo Senior Member
    2,763
    2,252
    Critters.
    Do you have a fuse chart or wiring diagram?
  9. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    I do not-
    I am suspecting bad Body Control Module-
    I am not getting 12v at the under hood fuse panel- at Dome lamp fuse-
  10. padroo
    2,763
    2,252
    If you areceived not getting power to either side of the fuse I would not expect the body ECU. I would think more on power distribution. I don't have wiring for your year but have a newer one. I will look at mine on my desktop and see where it is fed from, a lot of the times they do the same thing over many years.
    Maybe someone has the right diagram and will chime in.
  11. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    Thanks
    I have power door lock and mirror function -
    Just no radio life clock dome or smart key
  12. padroo
    2,763
    2,252
    Just following the dome light fuse back to where it is fed from shows it going to the
    IG1 1 relay. This is a newer diagram and if your car doesn't have this relay my information will be of no use to you.
    Full wiring diagrams are available from Do it Yourself Automobile Repair Manuals - Mitchell 1 DIY
    This is owned by Snap On Tool and if you work on your own car this is as cheap as you can go without going through Toyota.
  13. bisco
    52,001
    Your getting 12.5v at the jump terminal, but nothing in the rest of the fuse box?
  14. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    Well I have something as all functions except the radio, smart key dome and such
    When checking fuse for dome and amp- I get no voltage
    Also- when selecting audio on the touch screen- IT displays NO Audio-
  15. bisco
    52,001
    Sounds like rodents chewed on some wiring while it sat
  16. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    Very possible
    I’ll have some chasing to do
    I’m going to double check the smart key white box in trunk and verify I connected it
    I don’t remember u doing it when I moved the battery- it’s possible
  17. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    PROBLEM SOLVED
    So I had 12 to the Dome circuit- but not out after the fuse in engine bay
    I searched inside at the fuse block and found a red wire that had no power in any position, acc or Run
    Using a fused test lead and paperclip to probe- I jumped the dead lead w another 12v cicuit and all my lost functions returned. There is a break in the wire from the underhood block to the interior Body Control - so I bypassed that and have a 7.5 Fused lead in place -
    Pictures to come-
  18. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    Here are the pictures of the red dome lead - and the empty socket I’m taking 12 from.
    If I need to I will also find different 12v source - until then this will suffice.
    I can’t tell you how happy I am to have the features that were missing .
    SFO likes this.
