Back Up Camera Upgrade (Guide Lines)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by P13-T5, Mar 6, 2018.
  1. P13-T5
    P13-T5 Member
    60
    Hello Prius World!
    My 2013 Prius came with a reverse camera but didn't have guide lines. It make sense, given how the camera is mounted, which is offset to the left of the license plate; not centered. So my guess is Toyota designed it without guide lines to prevent miscalculations & rear collision due to its misleading angle.
    I decided to upgrade mine & luckily didn't have to wire it to the head unit like I did with my 2011 (T2). My '13(T5) was already wired so all I had to do was replace it with an aftermarket (AM) I got from Amazon . But not just a typical AM camera. This one has adjustable view & guide lines. I've used this twice now, one on my '11(T2) & now for my '13(T5) & I've always got good results.
    Now my view on my screen is almost perfect center, plus guide lines. Before, with an offset view & no guide lines, reversing was very confusing & took longer. Not anymore!
    The only challenge I faced was not having an available adapter for the camera. So I had to "jury-rig" it & made my own harness. Once I figured out the power & video source, it was pretty much plug & play.
    Materials Include:
    - Back Up Camera (back up camera: amazon)
    - breadboard wires
    - heat shrink
    - electrical tape
    - OEM part to mount your camera (Garnish Back Door: 76812-47030)
    The manufacturer's wiring configuration for the camera harness is as follows:
    POWER
    Positive: White
    Negative: White/Black
    VIDEO
    Signal: Red
    Ground: Black
    Hope this post saves you time with your camera conversation or upgrade.
    20180216_070310.jpg 20180216_203302.jpg 20180216_221751.jpg 20180216_221801.jpg 20180304_002937.jpg 224120_7504_0001.png
    Shibikku likes this.
  2. chinkin
    chinkin New Member
    united states
    My understanding is that the gen 3 prius's use a 6.5V camera. The camera you used is spec'd at 12V. This didn't pose any problem for you?
  3. 04priusnow
    04priusnow Active Member
    345
    201
    how do you adjust the lines?
    Pixel 3a XL ?
  4. Toodle
    Toodle New Member
    North Carolina
    Stumbled on this thread. I have a 2011 Prius with factory camera. I’d love to add guidelines without replacing the head unit. Did you say you did that?
