Input needed 2008 Prius
Discussion in 'Gen 2 Prius Main Forum' started by Da1sy, Jun 16, 2019.
  1. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    Everything on cars can be repaired and/or replaced if you choose. However, 300K on any "daily driver" is a really good run.
    Whatever you decide Da1sy, we wish you the best. ;)
    Da1sy likes this.
  2. PriusCamper
    PriusCamper Senior Member
    10,918
    4,426
    Pacific Northwest, USA
    I guess if there are two of us on here who agree with the outlier that techniquely they're no longer an outlier...
    Da1sy likes this.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    @Da1sy have me a call and we discussed possible options.
    Car has a P0A80 (replace hv battery) and p3017 (block 7)
    Hopefully she'll report back the final outcome.
    Da1sy and Raytheeagle like this.
  4. Da1sy
    Da1sy Junior Member
    Wisconsin
    Thank you so much Eric for helping me with this tough decision and taking the time to talk to me! Thank you to the rest of you also...you really helped! We have decided retire her.
  5. bisco
    48,974
    all the best!
  6. MilkyWay
    MilkyWay Active Member
    819
    357
    MI
    RIP. Are you going to get a Gen 2 or a Gen 3 next? Or....?
  7. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Are you going to sell it or save it for parts?
    kenoarto likes this.
  8. Center of Gravity
    Center of Gravity Junior Member
    25
    New Orleans
    I'm with Skibob and definitely an outlier. If you're going to sell it then let everyone know. Or at least that mechanic all the way up North near you. That car is definitely an easy flip, and after about $2,000 of work will get someone another hundred thousand miles down the road. I have a 06 with almost 300,000 and good for another hundred thousand. I have an 08 with 260,000 and not a lick of problems ever, just tires and oil. Your call but at least a good donation to someone in charitable need even for the $1,500 - 2,000 of upgrades on your wisely maintained car.
    I would surely have a conversation with the mechanic on your behalf; a little coming back to Jesus realignment.
  9. UberXking
    UberXking Junior Member
    San Francisco, CA
    What? I'm betting with a bucket and some towels is your fix. You have a small leak from the hatch or weld above the 12v battery area. Most on here smell opportunity.
    It's very likely that after removing the water and drying out the 12v battery area your Prius will operate fine. The idiot lights will all display if there is water touching or dripping on the positive of 12 v battery.
    moto x4 using PriusChat mobile app
  10. Center of Gravity
    25
    New Orleans
    Uber, I think you missed the point I was making, and the entire thread. Fix the problems surely, and the fix for the water is so simple it's under 50 bucks. But the mechanic was trying to Elud-to / associate this with the failed HV battery and three other completely separate issues, and I doubt she had a problem with the brake anti lock system other than a moist connector on the brake control ECU next to the 12-volt battery And while having added moisture in the bay may have contributed to the bus bars oxidizing there is definitely probably an imbalance in sector 11, or 12 as noted in her codes. A few thousand dollars into that car and another hundred thousand miles might not be worth it for many of us who can afford to go buy a new one, however for those in need, a few thousand dollars into that car be a blessing.
  11. egn83b
    egn83b Junior Member
    59
    Rarford nc
    For 5000 bucks go buy another prius 2008 prius with no problems lol
  12. T1 Terry
    T1 Terry Active Member
    585
    297
    For the money required to fix a car you really like compared to changing to a car you don't really know, I'd go with the devil you know.
    As far as the mileage, my wife still loves our ex Taxi Prius and drives it every where if it will carry what we need to pick up or deliver. She has just headed off to Adelaide, a few hundred kms round trip. Even though the ex taxi has over 720,000km on the clock, she still considers it to be ultra reliable. Mileage has very little to do with it, how well it was looked after and serviced is everything, if you know the vehicles history then you know if it has been looked after or not, base your decision on that.
    If you know anyone who is handy with a spanner, there are plenty of link on here regarding swapping out the traction battery pack. Up to you if you go for one out of a dismantled wreck or an after market one from 2K1Toaster, I put one from a dismantled wreck into my 2006 Prius and it has performed better than I had expected so $$ to happiness ratios I way in front.
    T1 Terry
