How to replace your Gen 3 spoiler, step-by-step with pictures
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ualdriver, Dec 14, 2015.
  1. Mendel Leisk
    41,865
    Luckily the three (or is it four...) times I've done this the hatch holds together and the garage door derails, lol.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Attached is the assist for @milkman44 :
    Looks more secure than before(y).
    milkman44 likes this.
  3. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I think it's so easy to do since the engine doesn't start till after we back out the door and we can't hear that the hatch is up. One time the wife backed out with the rear passenger door open, luckily the overhead door rail just pushed the door panel loose, Prius is one tough nut.
    Raytheeagle likes this.
  4. milkman44
    591
    386
    Ky
    I put a bracket on each end and it doesn't show at all with the hatch closed. Thanks for the attach.
  5. milkman44
    591
    386
    Ky
  6. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Well that’s one way to do it:).
    Find a willing participant (y).
  7. Martyelzz3
    Martyelzz3 Junior Member
    Sprague, WA
    I'd like to thank "ualdriver" for this post.(Thank you!) The 2012 Prius I purchased about a month ago had a high mount brakelight that wasn't working. I could only get 1 screw lose from the outside of the lens and after reading this I figured I could get the area opened and spray the screw from the thread side. I was wrong; but I did find the light was unplugged. Now the light works perfectly. I'm still not sure why someone would leave it unplugged.. oh well.
    Ricco likes this.
  8. sparkyben1
    sparkyben1 Junior Member
    When you see that the metal around a screw hole is deformed (up lifted), I use an auto body tool kit from harbor freight tools ($36.99}, to straighten the metal. Using hammer and dollies, I also add something on the inside of the hole to expand the contact area, which decreases the pressure against the metal from the head.
    I also do it on the oil pans, valve covers, etc. At times there isn't enough space for a fender washer I will cut heavy plastic to use.
  9. Solovey_PO
    Solovey_PO New Member
    Campbell
  10. CH1992
    CH1992 New Member
    kansas
    Great read! Really informative and I’m definitely going to use this in the future.
  11. OptimusPriustus
    OptimusPriustus Active Member
    335
    142
    Finland
    Duplicate
    #31 OptimusPriustus, May 15, 2023
  12. OptimusPriustus
    335
    142
    Finland
  13. KB9MNM
    KB9MNM Junior Member
    Oswego, IL
    Thanks for that! We took our '14 in to the body shop for repairs on the right front fender and somehow the spoiler seemed to have grown something in the middle of it. Looks like it was overheated during the accelerated drying process. This will need to be replaced at some time.
  14. Dave1UK
    Dave1UK Junior Member
    66
    London, UK
    Active
    Great post!
    I thought I'd add some extra photos of a brand new spoiler (photos are not mine but from eBay).
    I used them as a guide to assess what is/could be missing in terms of those rubber dampers or whatnot from mine as bought the car with the spoiler flapping and cardboard underneath it to support it, duct taped sides. I wasn't sure what was original and what the previous owner done to it.
  15. James Analytic
    351
    53
    Michigan
    Figured I'd note here for others to know. Hobby Lobby and other craft stores sell a 8.5x11" sheet of 2mm thick adhesive backed foam, for around a dollar US, that works awesome as a gasket material to make custom gaskets to replace those hatch handle, spoiler, tail lights and other holes that penetrate the metal skin gaskets. I bought a few sheets from Joann's when they had their clearance sale and I know Hobby Lobby still has in stock as I just got from there prior.
  16. Patrick Wong
    18,210
    6,512
    Thanks for the excellent directions. The tightening torque of the five nuts is 80 in. lb. I am going to use your directions when removing the rear spoiler on my 2015. It is not damaged but I want to repaint it.
  17. Cougar Zeke
    Cougar Zeke Junior Member
    WA
    Nice write up! Does anyone know the part number for the clips that screw down to the hatch (not the spoiler)?
    I backed into the garage and found that my spoiler was siliconed in place. The oval clips are in the spoiler, but have been removed from the hatch.
    I haven't been able to get an exact part number off the internet yet.
    Thanks!
  18. Mendel Leisk
    41,865
    Hopefully in this. The diagrams require a jeweler's loupe, but all the ID numbers are links, highlight the item in the list.
  19. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    This is crazy how much needs to be done to simply remove a rear spoiler lol
