Need advice for a long trip without access to charging.
Discussion in 'Prime Fuel Economy & EV Range' started by mistermojorizin, Jun 19, 2019.
  1. Tideland Prius
    16,066
    @jb in NE with regards to CHG mode to gain a few % before the downhill portion (and thus EV in B mode), can one achieve the same thing with regeneration then once we see 1-2% on the HSI, switch to EV Mode? Does that achieve the same result?
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    Yes. If the EV charge is 1% or higher it doesn’t matter how it got there. I think I started using Charge mode here to ensure it happened quickly.
    Tideland Prius likes this.
  3. mistermojorizin
    mistermojorizin Active Member
    310
    135
    usa
    2019 Prius Prime
    Ok, possibly a dumb question, is there a way to get HV mode to regen a little bit without using brakes or the gas expensive CHG mode. when on a flat? Like ideally I'd want just be able to put along on the freeway in HV mode at around 50MPG and have it bank 5 miles of EV range every hour or so.
  4. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    If there is no elevation change, then either traffic slowing/regeneration or pulse and glide are your other options at this speed.
    mistermojorizin likes this.
  5. bisco
    48,946
    there's no free lunch. if it were charging the battery on the highway, it would be costing you gas money
  6. Tha_Ape
    Tha_Ape Active Member
    271
    161
    Washington, DC
    Energy isn't free, If you're driving along on a flat road at 50mph, to charge the battery you'll have to use more gas (that's basically what charge mode does).
    I'm guessing you're looking for a less aggressive charge mode. You'd have to turn it on and off between charge and HV to get that effect. However it's probably better to let it run at a constant rpm to maximize efficiency so I'm guessing charge mode is the best option.
  7. Tideland Prius
    16,066
    Yes but the question is, is there a sweet spot to maximize the CHG mode? I think @bwilson4web did experiment. I recall it’s around 60mph? I’ll have to find that thread.
  8. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    Tested it today on a drive. Car in HV mode, but running in EV going down a hill. Shifted to "B" mode, ICE immediately came on and revved up to be the brake. In EV mode, car still running in EV, this does not happen.
  9. bisco
    48,946
    so the only question left is how much more regeneration in ev with b vs hv with d
    i have never used b, but it's pretty flat around here.
  10. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    A lot. When you select B in EV mode, it's like stepping on the brakes.
  11. bisco
    48,946
    but if you needed to slow down, stepping on the brakes would regenerate more as well
  12. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    That's true.. However, on a long downhill it's easier to put the car in "B" mode and you likely won't have to touch the brakes. You decrease your rate of slowing with the accelerator, essentially setting up one pedal driving.
  13. Tideland Prius
    16,066
    Currently on a trip with limited charging (although I am charging at the hotel now). I found that keeping the EV portion between 30-50% helps with mpg. Even though it’s been mostly highway 60-75mph with some construction, the trip total is north of 60mpg :eek: (Might be close to 65mpg). That’s very impressive.
    I save some EV juice in case you hit construction or traffic. That way, you can crawl through in EV mode without having the engine come on when the battery is low in HV mode like the regular Prius.
    Gonna drive through some mountain passes today. Let’s see how it does.
    So far, I’m impressed with the fuel efficiency in HV mode. (I eventually topped up by dealer tank at just under half tank lol. Couldn’t even empty it before refuelling)
    jerrymildred and Raytheeagle like this.
  14. Mendel Leisk
    38,217
    I thought this was gonna be the shortest thread ever: what to to do if you can't plug in, just drive it? Nope.
  15. bisco
    48,946
    lol, the shortest threads are the ones no one notices. :cool:
  16. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    Do we ever let a thread go short:whistle:?
  17. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    A few observations from my recent vacation trip.
    1. Using charge mode on the Interstate did not help at all. In fact, I almost never use it. I also saw little benefit at 60 mph, but it did seem to help a little.
    2. You can gain EV range going down big hills even starting at 0% (depleted). But it won't show any range until it suddenly says 0.6 miles or something like that. So it takes a BIG hill.
    3. I tried B mode, but didn't like it unless I wanted to keep the charge since you have to be in EV to keep the ICE off in B mode. (Yes, you can stay in EV and use it up, but you have to remember to go back to HV at the right time if you want to keep some charge.) So, for example, when I came down off Grand Mesa with 10% at the top, I left it in D and just dragged the brakes a little as needed while keeping it in HV. It charged to 98% before I got to the bottom. I then drove slightly downhill for about 10-15 miles in HV with ICE off and then back up hill on I-70 for about 20 more miles (still in HV) before the ICE started back up.
    4. Dragging the brakes seemed to me to recharge just as fast as B mode and was easier to control.
    5. Keeping some range in the battery, as @Tideland Prius mentioned, also seemed to help my fuel economy. I didn't notice, though, that 30-50% helped any more than 10-15%. At speeds under 70 mph, the car seems to do its own imitation of charge mode by cycling back and forth between HV & EV on its own. Having the extra juice seemed to allow it to go longer between mode changes. It was awesome at 60 mph.
  18. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    I found that I preferred B mode and one foot driving with the throttle only. Shifting between EV and HV is a pain though - I wish there were a steering wheel control or paddle for this.
    jerrymildred likes this.
  19. jerrymildred
    11,491
    14,100
    Tampa, FL
    Nice that we have a choice and can choose whichever we prefer. (y)
    jb in NE likes this.
  20. Tideland Prius
    16,066
    @jerrymildred I think you're right - as long as there's some charge, it doesn't matter if it's 10-15% or 30-50%. I guess it just depends if you're anticipating a traffic jam or construction.
    Drove through the Cascades, I was able to regen nearly 3kWh back. Mpg was impressive with only one full charge that morning - 3.5L/100km (67mpg) for the mountain trip, 3.4L/100km (69mpg) for the trip total over 1,350km (850 miles) of freeway and mountain driving with a small percentage of <40mph speeds (in town or construction on the freeway or traffic on the freeway). Trip MPG seems to back up the fuel tank gauge as it says I have a range of 302km (188 miles) left with about 3/8th of a tank remaining after I did about 650km (405 miles) on the current tank.
    I didn't get 98% charge like @jerrymildred did... I got about 23% (started at 3% and ended up at 26%). It was fortuitous as I was deciding where to use up my EV range and found a flat area with several villages/towns with 35mph limits so I switched to EV Auto (made no difference.. EV Mode would've been the same in retrospect) so that boosted up the mpg. (It was sitting near 4.7L/100km/55mpg before travelling through the villages).
    Oh and total gasoline usage was 12.445 gallons or 47.1 litres and that works out to 3.48L/100km or 3.5L/100km. Not bad.
    #40 Tideland Prius, Jun 24, 2019
    jerrymildred, benagi and Mendel Leisk like this.
