Spare tire and "advanced hybrid"
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by JasMayor, Jun 22, 2019.
  1. JasMayor
    JasMayor Junior Member
    22
    South Albany, VT
    2002 Prius
    I have a 2012 Plug-In prius, but just discovered it has no spare tire. Not wanting to use the onboard tire repair can I would like to buy a wheel and tire. The User's Manual says the wheel is 15x6J, and my current tires are P185/65R15. When enquiring about wheels I have been asked if my car is an "advanced hybrid." Apparently that is more important than the above data. How do I determine if it is an "advanced hybrid?"
  2. Mendel Leisk
    41,521
    I really doubt it matters.
    If you're ok with a full size spare, get an extra Prius rim and a tire in 195/65R15. Or for utilitarian, a Corolla steel rim (p/n: 42611-02471) would be fine. Or any semi-compatible aftermarket rim, say through TireRack, with adapter rings for the hub.
    If you want to get a compact spare, look up the part number for 3rd gen temp spare rim at McGeorge Toyota Parts (for one), and you can get the temp spare tire spec from a third gen owner's manual (downloadable in the "manuals" section at Toyota Tech Info website).
    Just in case it doesn't go without saying: this spare will have to reside somewhere in the cabin, it's not going to fit under the hatch floor.
  3. bisco
    51,998
    it doesn't matter. check salvage or eBay for a compact spare and tire. i think corolla and several others fit.
    there are some good threads here from back in the day for what people were using.
    i keep mine on the floor of the hatch
    Raytheeagle likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    You can also check Craigslist ;).
    Any spare tire from a regular Prius works. I picked my spare up from a wrecked 2015:).
    Just check the date code to ensure that the tire will be good to go for you(y).
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    I got a compact spare with rim on EBay. It was like new and cost about half what a new one would cost.
    Try searching for "16 17 18 19 TOYOTA PRIUS SPARE TIRE WHEEL DONUT 16" 5X100."
    Yea Right and Raytheeagle like this.
  6. jerrymildred
    11,517
    14,152
    Tampa, FL
    By the way, they were asking if you have a base or advanced PiP. It makes no difference at all. Both have the same wheels and tires.
    (Now that you have a PiP, welcome to the PHEV world!! Don't forget to update your profile. It helps when responders can see what we're talking about.)
  7. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Mine was $40. Thought that was a good deal;).
    @The Critic was up in Sac when I found it and he completed the transaction for me:).
    But they are out there(y).
    The Critic likes this.
  8. jerrymildred
    11,517
    14,152
    Tampa, FL
    That sounds like a GREAT deal!.
  9. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Probably could have done better but I opened with $40:cool:.
    My dickering skills need practice :oops:.
  10. Mendel Leisk
    41,521
    I happened to have a (3rd gen) Prius Plug-In rolling beside me yesterday. I don't believe it was ever for sale in Canada, so a bit of a rarity; think it's the first I've ever seen in the flesh. Nice rims...
  11. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    On the flip side of that I was at the dealer today for the 5k mile service on our Prime and saw the new Prius wheel covers:eek:.
    I’d make you cringe:oops:.
    But the PIP rims in the shrine are lookin better by the day(y).
  12. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    I [also] have a 2012 Plug-in Advanced. Some things that I believe the Advanced has that the Base does not— headlight washers, heads-up display, dynamic radar cruise control, larger higher def screen, more radio option buttons....
    jerrymildred likes this.
  13. bisco
    51,998
    electric seat
    PA Prius likes this.
  14. Mendel Leisk
    41,521
    Typo, or? The stock size is 195/65R15.
  15. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Some tire shops unfortunately put on the 185’s:cool:.
    @Pedal Logic currently has 185’s on his 2010 and there is definite early wear :(.
