Do wheels from other prius' fit?
Discussion in 'Prime Technical Discussion' started by Luconi, Jun 11, 2019.
  1. Luconi
    Luconi Junior Member
    MA
    2018 Prius Prime
    I'd like to buy a set of decent cheap stock wheels from an older Prius to use for winter tire beaters. I can get a set off of a 2010 prius for around $200. Will these work on a prime? Are there any wheels from other prius' model years that won't fit?
  2. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    I think Gen3 and Gen4 are interchangeable, but Gen2 had smaller OEM wheel IIRC. I don't know about Gen1 though. That said, for $200 you can also get aftermarket steely for that purpose. Or if you buy wheels and tires as a set, you can get quite a bit of discount sometimes. I got Michelline Xice 3 tires on alloy wheels mounted balanced ready to be installed from the Discount Tires for less than $500 total.
    edit: On afterthought, Gen2 OEM wheel also may fit. OEM tires were smaller size but the wheel was 15 in.
    #2 Salamander_King, Jun 11, 2019
    Luconi likes this.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The Prius v has a different bolt pattern than other Prius. The v is 5 x 114 versus 5 x 100 for other Prius.
    James Analytic and Luconi like this.
  4. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Let us know if you fit them on your Prime. I want to do the same, and lower cost aftermarket alloys are typically junk and corrode very quickly in winter use. Factory wheels in my experience are much more durable.
    Luconi likes this.
  5. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    I used exactly the same alloy wheels and tires off of my Gen II, that also had a slight layover on the Plug-in Prius, before ending up on the Prime. Although by the time I put them on the Prime they had different tires than what I started out with. I actually like them on the Prime, no wheel covers to mess with.
    I also used the winter alloy wheels and tires from my Wife’s Venza on her new NX300h. Actually looked awesome going from a 17” summer to a 19” winter. She liked it a lot.
    Unsupervised!
    iPhone ?
  6. Sarge
    Sarge Senior Member
    1,325
    784
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I also kept my (2006) Gen 2 alloy rims and use them as winter rims on my PiP. Same bolt pattern and tire size (195/65/15 and 5x100 I believe?). I believe some later trims of Gen 2 had an option for 16” rims(?), so not sure if those are the same.
    From what I know, I believe the same is true of the Prime, and I intend to keep my Gen 2 rims longer as my future winter rims on my ‘20 Prime with 5 seats and CarPlay when I eventually buy one. ;)
  7. Mendel Leisk
    41,385
    I think even Gen 2 rims will work, it's just the tire that's slightly narrower, but not sure on that. Gen 3 for sure will work. Also this Corolla black steel rim, it's what I use for snow tires:
    Corolla 15" black steel rims p/n: 42611-02471*
    One caveat with the older Prius rims, centre caps from gen 3 will not fit properly in gen 4, and vice versa. Toyota in their wisdom shifted the groove in the centre bore a bit, so the clips are different lengths. I would recommend to get centre caps, or use wheel covers: exposed hubs get pretty rusty, especially in snow tire conditions.
    * Going that route, I found a 2" ABS end cap made a semi-presentable centre cap. It's slightly loose, so I pushed on a bicycle inner tube "rubber band" first, to bridge the gap. This has worked for multiple winters, never flung off.
    James Analytic and WilDavis like this.
  8. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Yeah you are right, the lower cost ones do corrode quickly. Mine are about 14 years old and have a lot of surface corrosion on them. But then I knew what was going to happen to them because they were going to see a lot of salt. You can mitigate this somewhat by waxing them before they get put on the car before and after (when putting them away for the summer) every season.
    Unsupervised!
    iPhone ?
  9. Mendel Leisk
    41,385
    Yeah, a side benefit of two sets of wheels is convenience of waxing, more thorough too.
  10. James Analytic
    329
    51
    Michigan
    Gen 1 will definitely not fit. They are a 4 lug design and not 5x100. I didn't realize the Prius V are a 5x114.3 design. Glad I read this post.
    I recently made a video and FB post to store the info I found researching, as I do not like to use the gen 2 rims typically unless they are from an indoor kept or southern car. https://www.youtube.com/shorts/6tl5jXYA6Lo
    I've had a few gen 2 rim tires that appear to leak around the beads, based from what has been reported to me at the tire shops. Seems is always during the winter season, so no TireJect or TruckerCo sealant application times due to temps being lower than I prefer when using.
