Blower motor replaced yet again, 2012 Prius V
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by hadshouken, Jun 23, 2019.
  1. hadshouken
    hadshouken New Member
    TN
    As of this morning, my 2012 Prius V is on its third blower motor. This is the fan motor behind the globe box that blows air through the vents. Without it, you have no AC and no heat.
    Is this a common issue? I can understand once, but I only have 80K miles on it, and like I said it's the 3rd motor now. I'm wondering if I'm going to have the pleasure of changing this out yet again in another year or two.
    51,822
    welcome!
    no, it is almost unheard of. i think you need to track down the cause. perhaps the circuit board?
    i would start by having the voltages tested at each speed and compare to specs
    all the best!(y)
  3. Ronald Doles
    Ronald Doles Active Member
    230
    280
    Columbus, OH
    2015 Prius v wagon
    We are snowbirds from Ohio that spend the winter in Florida. We left our 97 Odyssey sit out while we are gone and I had the pleasure of removing my blower motor every spring when we returned. I don't know what it is about the blower wheel and why rodents think that it is an ideal place to winter.
