check hybrid system
Discussion in 'Gen 3 Prius Main Forum' started by Zaza 13, Jun 26, 2019.
  1. Zaza 13
    Zaza 13 Junior Member
    74
    Israel
    prius 2015, 100k miles check hybrid system, battery is getting charged on down hills, but nothing works (ev, eco, pwr). car runs as usuall (with no hybrid system) . what could be?
    52,093
    inverter pump?
  3. Zaza 13
    74
    Israel
    could be problems with inventer, not only pump?
  4. Zaza 13
    74
    Israel
    if problem is with battery, can the car charge it?
  5. bisco
    52,093
    12 volt?
  6. MilkyWay
    MilkyWay Active Member
    823
    359
    MI
    Did you scan the codes?
  7. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Which of the batteries? Aux or HV?
  8. Zaza 13
    74
    Israel
    hv battery, 12v is ok.
  9. bisco
    52,093
    the engine charges the hybrid battery, even if it is weak. if it is bad, you will get dash lights
