Brake dust? weird
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Eric Vasaio, Jun 30, 2019.
  1. Eric Vasaio
    Eric Vasaio New Member
    BC, Canada
    2013 Prius Plug-in
    To my understanding, Prius Gen3 won't engage physical brake pads until Charge bar is filled up or under emergency brake. And that is why its bake rotors and pads can last like forever.
    But recently, I found a lot of black particle dust showed up on my 2013 Gen3, both on all 4 rims and body sides. I guess they're from brake dust like other vehicles. But I was driving it like textbook, almost no hard brakes at all. I assume that pads are seldom used.
    So, where does this black powder come from?
    Have to admit that I've just got this vehicle only for a month and half, still trying to figure out its norm.
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    I think you will find that the mechanical brakes almost always begin to engage at the end of each stop. They also hold the car still while you are stopped on an incline. So, my guess is that it really is brake pad dust. Now, maybe someone else can tell us about the benefits of various brake pad compositions as compared to Toyota's original formula, but yes, I'd say it's brake dust. I use an aerosol product from Armor All called Outlast(TM) Brake Dust Repellent. A small can is good for 4 or 5 monthly applications.
    Eric Vasaio likes this.
  3. bisco
    52,277
    i have read that the brakes are applied in concert with the regen, the harder you step on them, the more friction.
    not only at the end of the regen, according to those with a scan gauge.
    if you think about it, that's still a lot less wear than pads only.
    i have never noticed any dust though, but haven't owned a white prius either
  4. Pluggo
    608
    534
    I almost forgot to mention something important: your pads could be dragging due to calipers needing lubrication. This will also cost you in gas money. I think the standard test is to jack up the wheel and see if you can spin it for one revolution before it stops.
  5. fuzzy1
    10,583
    All braking under 7 mph is always by friction pads.
    Friction pad braking is not just for emergency and battery-full conditions. Prius regen has capacity for only light-to-moderate braking (depending on speed), and many drivers regularly exceed this with their normal medium braking, requiring friction to make up the difference. And as other have pointed out, friction is often used in concert with regen to make braking more immediate and (sort-of, nor perfectly) seamless, so the pads are not fully disengaged as often as you think.
    The friction elements can last 'like forever' because careful use of regen can cover a large majority of the overall braking work. But not everyone achieves this. In fact, without changing their braking styles from prior traditional non-hybrids, most drivers won't achieve majority regen.
    #5 fuzzy1, Jun 30, 2019
    Pluggo, Eric Vasaio and jerrymildred like this.
  6. padroo
    padroo Senior Member
    2,763
    2,252
    Ceramic brake pads almost totally eliminate brake dust. I installed them on my Plymouth Prowler several years ago and almost eliminates brake dust.
    Pluggo and Eric Vasaio like this.
  7. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    If for some reason your in neutral gear, and press the brake pedal, brake pads will engage at any speed. Also in reverse.
  8. Tideland Prius
    16,601
    It’s also possible the previous owner replaced the brake pads with some aftermarket ones that produce more brake dust than OEM.
  9. Eric Vasaio
    BC, Canada
    2013 Prius Plug-in
    Thank you ALL. fuzzy1 explained very detailed thanks again.
    Pluggo, my gas mileage wasn't bad, 60-70MPG even on highway driving (it's a plug-in version), so I don't think brake dragging is an issue here. But thanks for your input, appreciate it.
    Pluggo likes this.
  10. johnHRP
    johnHRP Active Member
    645
    189
    KA, DE
    Excel
    What I found in 3rd gen Prius, some rear brake pin bolts need re-greasing with Silicon grease, some could jammed and caused premature wear in pads and rotors. For the front brake, they are usually fine, just weird looking corrosion from light use. HOwever, it gets really really hot when you are going downhill in alps or rocky mountains on D all the time. The battery capacity is already too full and the regenerating brakes is stopping and the brake disc gets really hot. Putting to B /engine Braking mode helps the brake fading.
