Eek! $70 oil & filter change
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Jun 29, 2019.
  1. Salamander_King
    Salamander_King Senior Member
    11,023
    8,963
    New England
    $70 for a synthetic oil change is pretty good. With a coupon, I can get the oil and lube done at my dealer for $39.99 sometimes, but they always try to find something else to tack on. Bait and switch.
  2. Trollbait
    12,653
    Didn't have that problem at at the dealer, and they were free changes included with the car.
    Last time, they overfilled it by a quart.
  3. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    That Subaru engine make me think about what a modern Corvair engine might look like. Flat 6 with an easy to change oil filter. Modern Subaru has pollution control equipment where the old Corvair had ignition equipment and carburetors.
  4. Mendel Leisk
    41,830
    For the fourth gen the Canadian oil change interval matches the US. Still, such arbitrary (and wide) skews in policy make me sceptical it's all engineers driving the changes.
    cyberpriusII likes this.
  5. Trollbait
    12,653
    Yeah, the only technical reason I can come up with is the climate extremes you have in many parts of the country. Those could lead to more water in the oil, which leads to the acid neutralizers being used up faster.
  6. Stevewoods
    Stevewoods Senior Member
    663
    1,194
    Seattle, WA
    My independent mechanic STILL swears by 3K oil changes.
    He says it is not about him making $, but he honestly thinks it is best for the car/engine. He says that knowing that I usually change my own oil.
    I do respect him and I do think that he is not one of those out to cheat the car owner.
    As the site BITOG proves, oil changes are almost a religion.
  7. Sr5dude
    Sr5dude Member
    58
    55
    Gilroy,California
    My last service at Toyota was $112. Toyota sent me a survey. I mentioned the services being more price competitive. The service manager called me saying that I was out of touch with prices and they were on target!
  8. Mendel Leisk
    41,830
    I'll bite: what did they do? I'm guessing oil change and tire rot?
  9. cyberpriusII
    1,157
    1,822
    Mars Hotel
    I am happy. Not changing oil now until 5K and I think it will be a breeze with the Fumoto and the top-mount filter.
    I am doing pretty well since an accident essentially crushed my entire right side. Only issue is I still have trouble with full extension of right arm....but enough oil changes and that may change.
    kris
  10. bwilson4web
    16,332
    I did have to put some window washing fluid in the Tesla. Also, I had to clean both sides of the wiper blades and clean out to road grime where the wipers stop. I'd noticed in the built-in dash cam video that one swipe was clean but the return put a layer of road stuff to fuzzy up the video. Thanks to warmer temperatures, no need to add air to the tires . . . yet.
  11. Trollbait
    12,653
    Well, it is technically best since you are replacing the oil long before any of the additives get used up.
    But when was the last time he had seen an engine actually fail because of the oil being changed at just the manufacturer recommended intervals? Not turbos.
  12. Stevewoods
    663
    1,194
    Seattle, WA
    I feel guilty. I have not driven my Outback much at all. The beauty of retirement. I thought I would use it alot this summer, but so far, no.
    Well, lot of summer left. I will say that the base engine is a bit more anemic than I suspected, but it does the job.
