Bigger Oil Filter?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by GeneTherapist, Apr 4, 2019.
  1. GeneTherapist
    GeneTherapist Junior Member
    Drivers Seat
    CNC97:
    With the right oils, the oil burn is very slow. I'll give the thread a recap though for those who got distracted:
    Here's what I've learned so far: Adriatic Spindle Oil (a specific type of oil additive with CAS 64742-65-0) is an ingredient in the OEM Toyota Oil used at 1-5% and is used in heat transfer applications up to at least 600F as well as being used for a motor treatment/engine cleanser. It's purpose is likely to reduce heat at the point of contact where some part or another gets hot enough to burn other paraffinic oils in absence of CAS 64742-65-0 with low flash point temperatures and keep them from accumulating where some oils intentionally leave waxy deposits to prevent engine wear in engines were design tolerances aren't as close. It's the absence of Adriatic Spindle Oil (and there are many spindle oils, all with different chemical properties) and the accumulation of burnt low flash point paraffinic oils that leads to oil burn in the first place per the hypothesis that I'm currently using. I won't know if I actually do need to replace the engine or if it was just maintained with non Toyota oil and can just be cleaned up and put back on Toyota's recommended oil with the additives necessary to reduce or eliminate oil burn and maximize engine life(people in lower income countries will put a new paint job and a couple hundred thousand miles on these econo luxury cars when we're done with them). Anyways, the initial oil burn would seem to be higher in cleaner engines.
    I've also stated that Edge/Magnatec tends to burn more oil and is designed to burn given the low flash point ingredients and Toyota notes that their cars can be expected to burn oil (that checking and adding oil is normal maintenance), this is likely b/c they know that non Toyota oils lacking ASO will generate more friction in some part of the engine and burn lower flashpoint oils which the engine isn't designed for. If I was topping up with Pennzoil, the oil burn would be pretty negligible, and once I clean all of the burnt low flash point paraffinic oil residues out of the engine and switch to Toyota oil or Pennzoil with the necessary ingredients, I hypothesize that this engine will stop burning oil and that I will have helped many owners solve their oil burning eco car dilemmas and get back to having a nice convenient, reliable, and efficient car. At present, my hypothesis is that Prius owners are under informed as to the importance of oil ingredients and could be spending money on engine repairs and oil top ups that could be better spent on other areas of vehicle maintenance.
  2. Mendel Leisk
    38,718
    Spindle oil is mentioned in the Repair Manual, as an O-ring lubricant when installing the fuel injectors. They say to use either spindle oil or gasoline. I looked it up too, seems like pretty obscure stuff, often sold in 5 gallon pails.
  3. cnc97
    cnc97 Senior Member
    1,419
    1,528
    Evansville, IN
    Instead of using obscure ingredients to make a “snake oil” that your car won’t burn, just use the Pennzoil you mentioned that doesn’t burn off. “Negligible” is the word that you used.
  4. GeneTherapist
    Drivers Seat
    There are lots of Spindle Oils, only this one afaik is useful for heat transfer which can reduce burning by taking heat from other oil molecules. If I can get the engine clean enough to either switch it back to Toyota oil or add CAS 64742-65-0 (Adriatic Spindle Oil... not it's only name, but the most memorable of them) to the Pennzoil to reduce or eliminate oil burn and thus reduce or eliminate the risk of failure due to oil burn, that would be ideal, especially for resale value. Not to mention the higher temperature internal components will likely last longer. Duralube could be the answer if used in 6oz quantities.
    At one point, with Seafoam in the oil, I had 10k used oil (castrol magnatec of all things) not burning a drop! Which would be nice and convenient for added peace of mind, but it had to be changed. Ideally, I won't have to add much oil to the engine, and it'll be pretty clean when I do the valve adjustment in a few thousand miles, meaning my tools will also take less time to clean. A tidy engine is a tidy toolset! It also occurs to me that if that works, I might be able to save a few more dollars using supertech synthetic with Adriatic Spindle Oil which would still be ~$4 less than Pennzoil.
    As far as obscurity goes... if you find a common use for it and post on a forum or youtube, someone will usually start selling it. When they don't, it involves someone's still in force patent. That's the power of public forums!
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    The "power" of public forums is two fold:
    Good information is disseminated at the speed of light.
    BAD information is also disseminated at the speed of light.
    Often the BAD information is presented so skillfully that it looks good.
    Self-proclaimed experts usually are NOT.
  6. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    sort of like self proclaimed "stable geniuses" ... Donald E Coyote "Super" Genius!
    edthefox5 and NortTexSalv04Prius like this.
  7. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    FYI
    To OP and others about filter size . I did a search on ROCKAUTO .
    All of these models share the same oil filter size
    YARIS 05-09
    PRIUS Gen2 04-09
    Matrix /Vibe out of production
    Echo
    Prius C
    Both FRAM and BOSCH same
    Is this thread about a mechanical physical size oil filter or oil refinement /oil type
  8. Mendel Leisk
    38,718
    Honda is similar: every one I've encountered uses the same filter. Used to be their motorcycle filter, fwiw. At least it was dimensionally identical.
  9. GeneTherapist
    Drivers Seat
    It started as an oil filter size topic, but it's branched out to explain my oil experiments.
  10. waldox
    waldox Junior Member
    69
    toronto
    mobil m1-209 extended oil filter works with my 2008 prius, its a crossover/minivan/truck oil filter
    sells for ~$14 canadian on sale at canadian tire
    could probably leave it in and change it every other 10kkm (6.2k miles) oil change, but have been changing it every 10k and flushing with seafoam/mmo since its pretty cheap
  11. TMR-JWAP
    TMR-JWAP Senior Member
    6,226
    5,910
    Columbia, SC
    This is some of the funniest stuff I've read in a long long time.........................
    Gene, have you even looked at what's involved in adjusting valve clearances on a Gen 2 Prius....I'd venture to say you're opening up a can of (unnecessary) whoopass on yourself. You want to tackle this, but won't remove an oil pan?
    ..and good luck with your ideas about the HV Battery....I hope that all works out well.
    I'm just gonna go get a bowl of popcorn and sit back.....
    Travis Decker and Aaron Vitolins like this.
  12. GatorJZ
    GatorJZ Member
    285
    17
    You realize Toyota dosn't actually make oil filters? Your "OEM filter" is a rebranded Denso.
  13. bisco
    49,470
    whaaaaaat???????:eek::eek::eek::eek::eek:
  14. dolj
    dolj Senior Member
    7,651
    3,862
    Wellington, New Zealand
    While you are correct in saying that Toyota do not actually make the filters and contract Denso to make them on their behalf (not withstanding the ownership connection Toyota has with Denso), it does not stand to reason that a Denso equivalent filter is the same as the Toyota branded one. That would depend on the contractual arrangement that Toyota has with Denso, and whether there is any Toyota IP that is protected by said contract. Not saying any of this is so, I honestly don't know, all I am saying is that your inference is not necessarily true.
    To further complicate things, the Toyota filter I buy in NZ for my Prius is totally different on the inside to the Toyota filter available in the US for the same Prius. Both Toyota branded and both made by Denso. Different part numbers, though.
    #54 dolj, Jul 2, 2019
  15. GatorJZ
    GatorJZ Member
    285
    17
    Denso has oil filter factories in Japan, Thailand and China. That is the most likely explanation for the differences you have noted.
  16. dolj
    dolj Senior Member
    7,651
    3,862
    That, and the fact Toyota has different specs for different markets.
  17. GatorJZ
    GatorJZ Member
    285
    17
    You base that assumption on what exactly? The thought Toyota has different specs for the same oil filter application in different markets is a bit of a reach.
    #57 GatorJZ, Jul 2, 2019
  18. lech auto air conditionin
    830
    601
    261
    san francisco
    Amsoil makes a bypass filter that you can mount in your trunk or anywhere you can find space for it and with the extra hose your oil capacity will go up to roughly 9 quarts. Are used to go 50,000 miles in between oil changes using Amsoil synthetic I was over 300,000 miles on my three cylinder Chevy sprint before a car hit and totaled out the vehicle. Geo Metro did the same thing to it. That was back when I was driving roughly 100,000 miles a year and I got tired of changing oil every week or two. If you were using a good synthetic oil changing it every 5000 miles you should not have any bad buildup in your engine up varnish. But if you do has mentioned up above seafoam works great just use it 500 miles before you change your oil you can also use it in the fuel system. Or a few days before you change your oil add a quart of Marvins mystery oil and then change your oil. My 2009 Yaris with over 300,000 miles when I last inserted a borescope down the cylinder and looked behind the exhaust valves just have a light black suit film can still see all the metal. Behind intake valves and intake runners in the head bright shiny clean metal like the day it rolled off the factory floor.
    SFO likes this.
