8 year maintenance question
Discussion in 'Gen 3 Prius Main Forum' started by Snowswan, Jul 2, 2019.
  1. Snowswan
    Snowswan New Member
    own a 2011 Prius with 15,000 miles on it. The dealer is recommending fluid changes (inverter, brake, coolant and one more). Cost is about 600-800. No issues with this car. I am not “car smart”, so what happens if you don’t do the suggested maintenance? Thoughts and opinions are welcome and appreciated. Thank you. I’m
  2. ASRDogman
    ASRDogman Senior Member
    6,084
    3,271
    Read the owners manual. There is a list of when each service is due.
    With the added service of replacing the transmission fluid at approx. 50,000 miles.
  3. Mendel Leisk
    38,705
    Can you confirm that? You didn't maybe mean 150,000 miles?
    Raytheeagle likes this.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Snowswan likes this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Or 115k miles;).
    Either is more reasonable for the dealer recommendations:).
    Easy to not put in a one or zerowhen there are a couple in series(y).
  6. Snowswan
    Snowswan New Member
    It is 15000 miles (not 150,000 or 115,000). Very Low Mileage, but 8 years old.
    Mendel Leisk and Raytheeagle like this.
  7. Snowswan
    Snowswan New Member
    It is 15,000 miles. The reason I am asking the question is because of 1) it's age and 2) the low miles. I want to make sure that the dealer isn't ripping me off and that the maintenance is truly required. Thanks to all/
  8. bisco
    49,434
    don't trust the dealer, follow the schedule that came with your car. some things are due at mileage, some at time, some whichever comes first.
    James Powers likes this.
  9. bettergolf
    bettergolf Active Member
    424
    339
    Sanford NC
    Most here won't agree with this but.....I'm 65 years old and have never changed anything due to time...only usage (miles). Never had a problem either. I keep my cars a long time and I've never changed the following in any of them...engine coolant and brake fluid. I've never had a problem related to either of those. I do stick to oil change schedule and I tend to change the transmission fluid earlier than the recommended intervals...especially when it's supposed to be "good for the life of the car" as some cvt's fluids supposedly are.
    At 15k miles I would only change oil until at least 50k but probably even beyond that. But hey that's just me.
    royrose and mikey_t like this.
  10. Mendel Leisk
    38,705
    Yeah 15k miles is VERY low, almost a "stored" car. I'd be thinking about the 12 volt battery, and maybe considering a brake fluid change. The latter is not mentioned by Toyota USA, but their Canadian counterpart says tri-yearly or 48k kms.
    Honda Canada says tri-yearly, regardless of miles.
    CR94 and Ed Beaty like this.
  11. Johnny Cakes
    Johnny Cakes Senior Member
    1,015
    764
    Virginia, USA
    Good link to the manual, although there is so much in their about special driving conditions and needless CYA stuff ("Check drivers floor mat") and basic "inspect / check" that it is a bit hard to distill.
    So creating the Reader's Digest version In terms of "no inspection, just replace" maintenance.
    It seems like they recommend every:
    5,000 miles = tire rotation
    10,000 miles = oil and filter
    30,000 miles = engine air filter
    100,000 miles = coolant (every 50,000 thereafter)
    150,000 miles = inverter coolant (every 50,000 thereafter)
    Did I miss anything?
  12. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Cabin Air filter Clean at 30,000, replace at 60,000
    Spark Plugs replace at 120,000 (or 150,000 in CARB states)
    I would add PCV valve (with Spark plugs) and Transaxle drain and fill, (30,000, 100,000, and than every 100,000) but they are not in the manual.
    If you really skip the inspections, do not take passengers, no point in killing others.
    Johnny Cakes likes this.
  13. royrose
    royrose Senior Member
    1,389
    949
    Foot of Pikes Peak
    The dealer is indeed ripping you off.
    I agree.
