  1. Sloth.Power.Prius
    Sloth.Power.Prius Active Member
    104
    331
    Monterey Park
    No comment :whistle:
  2. Sloth.Power.Prius
    104
    331
    Monterey Park
    Yeah, but that's just more work I gotta deal with. So I'd rather make more 'friend' if you know what you I mean. :D
  3. m3pare
    m3pare Senior Member
    679
    1,818
    SoCal (626)
    I went to a random smog station and they passed me with OCC mounted up top and oily clear braided hoses exposed. I guess it just depends on the technician.
    sfv41901, Putu Ariawan, RMB and 3 others like this.
  4. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Where did you get the mounting bracket for the Oil Catch Can?
  5. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
  6. Sloth.Power.Prius
    104
    331
    Monterey Park
    Hybrid Pit got me with that mounting bracket. I believe the mounting bracket was machined made by @Burna J
    sfv41901 and Dylan Doxey like this.
  7. BlkGenIII
    BlkGenIII Active Member
    86
    258
    SoCal
    True true!
  8. Sloth.Power.Prius
    104
    331
    Monterey Park
    So here it is, the oil inside the catch can after about 5k miles. Without the OCC, these oil would have gone back to your engine. Btw, I did the EGR and OCC installed back in April (had around 88k miles, now I'm at 93k miles).
    icyrius, sfv41901, Max Taiwan and 6 others like this.
  9. 04priusnow
    04priusnow Active Member
    345
    201
    Auto headlights and fog light control. my 3 had neither.
    Pixel 3a XL ?
  10. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    Picked up an Injen Intake from a fellow prius modder. (he had a pretty clean pip) also have some Tien Coils that I picked up from a diff guy on CL that were never installed. I ended up needing to buy new tires so the Coils have just been sitting but the intake should be going in this week. Had to order that little rubber thing to help with the vibrations while connected to the motor along with a new filter.. Probably didnt need to get a new filter but I wanted it to be more "new to me" :cool:
  11. Sloth.Power.Prius
    104
    331
    Monterey Park
    I'm finally joining in on the red bullet gang.
  12. ASRDogman
    ASRDogman Senior Member
    8,012
    4,069
    Does this improve the fuel mileage?
  13. NewHybridOwner
    607
    283
    W. Michigan
    That much oil in only 5K miles!!! Is that typical?
  14. 04priusnow
    345
    201
    installed mine also today
    Pixel 3a XL ?
    Max Taiwan likes this.
  15. Sloth.Power.Prius
    104
    331
    Monterey Park
    Testing in progress...I'll post an update later when I get more driving in.
    Dylan Doxey likes this.
  16. Sloth.Power.Prius
    104
    331
    Monterey Park
    I guess so :unsure: Not sure if that's normal
  17. 04priusnow
    345
    201
    I haven't seen mine get dark like that. winter is when it fills quickly but looks like a cappuccino in color, milky brown. summer it catches some oil but not much and looks like fresh oil.
    Pixel 3a XL ?
  18. Max Taiwan
    Max Taiwan Active Member
    428
    384
    Taipei
    2018 Prius v wagon
    WOW that in 5000 miles! That is crazy!!! Can not imagine that! Is the 1.8l port injected or cylinder direct?
  19. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    How did you find the installation process?
  20. ASRDogman
    8,012
    4,069
    Okay, thanks!
