Voice search for navigation?
Discussion in 'Gen 4 Prius Main Forum' started by Jacob Anderson, Jun 22, 2019.
  1. Jacob Anderson
    Jacob Anderson New Member
    Arizona
    Three Touring
    I am trying to use voice recognition to search for directions to a destination. Can this be done? I have a 2016 Prius 3 touring. Voice recognition has no idea what I am saying and when I use a destination search it says no data?
  2. Tideland Prius
    16,597
    You may be trying to search by Bing search on Entune instead of the native navigation's search.
    After pressing the "voice" button on the steering wheel, say "navigate to an address" or "search for an address" or do a two-step process - "navigation" then wait for the prompts then "address"
    krmcg likes this.
  3. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    Entune voice recognition sucks! Seriously it’s terrible. Every time I try it passengers in my car laugh! If I do get a response it’s always a dead end. So I go to my iphone and ask Siri, it always gives proper direction. You have to wait for the. Toyota/entune/whatever to connect, so be patient.
    jb in NE and krmcg like this.
  4. krmcg
    2,592
    2,392
    Whittier, CA
    There is a method of teaching your NAV unit your voice and also learning the best method of asking for help. Didn't make a lot of difference for me, but that might help.
  5. davecook89t
    davecook89t Senior Member
    1,090
    826
    Washington State, Florida
    Four Touring
    The Voice Command system is described in Pages 133 to 143 of the Navigation System Manual. The manual doesn't contain a complete list of available voice commands. Neither did the manual for our Gen 2 Prius, but I have a list (attached) that works for Gen 2 (can't remember where I got it). I assume the list for Gen 4 would contain the same commands and then some. I hope this helps.
    Jim in NC and krmcg like this.
  6. tucatz
    501
    417
    Manzanita, Oregon
    Four Touring
    Yes, I’ve done this several times. It’s still terrible.
    I would have to be a coder to understand this list
    #6 tucatz, Jul 9, 2019
    krmcg likes this.
  7. davecook89t
    1,090
    826
    Four Touring
    Hopefully, formatting the file will make a difference. The 2nd column contains an alternate command that can be used to accomplish the same task as the command in the 1st column. There are a total of 228 different Navigation commands, for which there are 132 alternates, 44 Audio commands, with 32 alternates, and 49 Climate commands, with 24 alternates.
    Tideland Prius likes this.
  8. davecook89t
    1,090
    826
    Four Touring
    Well, I tried, at least.:(
    tucatz likes this.
  9. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    As you have noted, the voice commands are something worse than terrible. Like a previous commenter, my passengers and I get a good laugh at some of the replies to plain voice commands. I walked through the "train the voice" process, and it is still worthless.
    tucatz likes this.
