Engine Problems in PiP!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Yehudah Weisz, Jul 12, 2019.
  1. Yehudah Weisz
    Yehudah Weisz New Member
    Carlsbad, CA. 92011
    PLEASE HELP!!!
    I have a 2012 Prius Plug-In Advanced (now called the Prime)...
    I've only done 3 oil changes... one for each 100,000 miles... no other maintenance done
    Now I have Cylinder Misfire and changed Coils, Plugs, and Injectors... doesn't fix issue. So mechanic says I need to rebuild engine or new engine... seems a bit much!!!
    Codes I'm getting:
    P0300
    P0301
    P0304
    P219A
    It mainly rattles when I barely press on gas peddle (like in heavy stop & go traffic).
    Thank you,
    Y.W.
  2. JC91006
    JC91006 Senior Member
    16,470
    8,383
    If you've done oil changes every 100,000 miles, then you have an issue.
    A common problem at high mileage is a blown head gasket. So that's probably what you have. Do a compression check
    Woodst0ck likes this.
  3. NewHybridOwner
    NewHybridOwner Active Member
    607
    279
    W. Michigan
    AFAIK, it's only comparatively recently that any manufacturer has claimed that its oil is good for even 10,000 miles (and I'd be reluctant to change my oil that infrequently). Is that what you meant? You inadvertently added a zero?
    If you really did change the oil only at 100,000-mile intervals, I'm surprised that it's even running at all.
  4. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Name was never changed, it's still a 2012 Prius plug-in model.
    Oil changed every 100,000 miles and still running, this is a prius chat record as far as I know.
  5. Yehudah Weisz
    Carlsbad, CA. 92011
    Blown head gasket is very possible... how much something like that cost?
    I did look at Engines & Transmission on eBay and they seem fairly priced. My only concern is that many (not all) are from Japan that promise to have 40k-60k miles.
    I'm looking at an engine for around $1150 and Transmission for around $300... plus installation
    PLEASE ADVICE!!!
    #6 Yehudah Weisz, Jul 14, 2019
  6. bisco
    48,999
    welcome!
    try replacing the pcv valve
  7. JC91006
    16,470
    8,383
    you don't need a new transaxle, just need to fix the head gasket (if that's confirmed to be the problem)
    Raytheeagle likes this.
  8. Yehudah Weisz
    Carlsbad, CA. 92011
    I know I don't need another Transmission (transaxle), but since it has 310k miles and if I'm already removing engine and paying for that labor I figure I should just put the matching 40k-60k mi. Trans that went with the Engine.
    - Then I can change shocks & struts and a "new-ish" car is what I'll have... or best possible for Lyft/Uber
  9. Mendel Leisk
    38,259
    Just to confirm, the car has over 300,000 miles? And 3 oil changes in all that time?
  10. cnc97
    cnc97 Senior Member
    1,418
    1,525
    Evansville, IN
    This is what I told him on the thread he hijacked on the v side....
    310k mile in 2 1/2 years. That is 339.72 miles per day for 912.5 days. At normal intervals (10k miles)the car needed an oil change every 29.435 DAYS. You changed the oil only 3 times. I, even after knowing my replacement engine that I put in had around 12k miles on it, get nervous exceeding 5k miles on my oil change by more then a couple hundred miles. Yet you changed the oil around day 304.16 or so.
    At any rate, going purely by miles, the engine is past the “average” head gasket/oil consumption mileage window of 150k miles by 2x. I would search on
    Car-Part.com--Used Auto Parts Market .
    That’s where I found the replacement engine I installed. You can sort by price, miles, or distance from you. And the prices are just as good, if not better then eBay. Especially if you can go pick up the engine in person.
    My final thought on this. After you do replace the engine. Please stop abusing your Prius and change the oil at the recommended interval!!
    Yehudah Weisz and Mendel Leisk like this.
  11. bisco
    48,999
    i mean, if you can go 300k in a gen3 engine with 3 oil changes and no other major maintenance? maybe he's on to something?
    Yehudah Weisz, noonm and Mendel Leisk like this.
  12. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Maybe Toyota imbued the vehicle with car spirits that keep it running long past the point that it should?
    Yehudah Weisz likes this.
  13. Mendel Leisk
    38,259
    Someone here went a bit over 20k miles before changing oil filter, due to problems breaking it loose. It looked pretty bad...
  14. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    @The Critic has an Infiniti engine that was run for 40-50 k miles and the oil wasn’t changed:cool:.
    Guess what happened to that:eek:.
    I just hope the replacement engine for that FX is treated better(y).
  15. PA Prius
    PA Prius Active Member
    753
    240
    SE Pennsylvania
    OP, in the V thread you said you bought this car 2.5 years ago. That is about when I bought mine and I was happy to find one with only 39,000 miles. It sounds like you got yours with only 10,000 mile on it. Nice find!
    You also say in the other thread that you've never owned a car long enough to need to replace the brakes or tires. I went almost 200k in my Gen2 before needing to replace the brakes, Congrats to you on going 300k. My PIP now has 67k miles on it and the original tires are coming to an end. I'd be glad to know which tires you ran for 300k since I'm definitely interested in going that route, as long as they are LRR. :)
    Yea Right likes this.
  16. Yehudah Weisz
    Carlsbad, CA. 92011
    I got it with 22k miles on it. I used Pirelli P4 Plus... but sorry forgot to mention it, but that is the one thing I replaced twice... I got about 90-120k miles on tires
  17. Mendel Leisk
    38,259
    That's astoundingly good.
  18. bisco
    48,999
    i got 40k out of the oems
  19. PA Prius
    753
    240
    SE Pennsylvania
    I do see that the P4 Plus are warrantied for 90k, so your 90 to 120k is very good. I currently have 68k on my '12 PIP and the original tires are approaching their end, although about 8k of these miles were on Michelin X-Ice.
  20. bisco
    48,999
    do you state every 5k?
    how often do you check alignment?
    what pressures do you run?
