Unkown part - Help identify
Discussion in 'Gen 2 Prius Main Forum' started by US_BLUES, Aug 8, 2013.
  1. US_BLUES
    US_BLUES Junior Member
    Hello,
    I had my new to me prius up in the air and noticed this broken part under the car. It looks like a lightbulb, but all of my lights and signals are working. This is front passenger side next to the radiator. Anyone know what this is?
    PS - Car was in an accident before I purchased it.
  2. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I'm not 100% certain, but it looks like it might be the external temperature sensor. Does the external temperature display correctly on your MFD?
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The white rectangular plastic piece looks like an electrical connector. Whatever was connected to the other side looks like it was broken off and the two wires are just hanging down.
    Is this on the engine side of the radiator or the grill side? If on the grill side then uart could be right about the external temperature sensor.
  4. US_BLUES
    External temp sensor works on the car reading 90 degrees now, but it looks like this sensor couldn't possibly be working with the grime and exposed wires. Any other ideas? No CEL's showing on the dash.
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    unk part.jpg Does it possibly plug into here?
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    I think its the Engine coolant temp sensor. If so that may mean there's no engine coolant because I think the sensor is in the coolant stream and it fell out of its sealed hole.
    Take the topside black plastic engine cover off and open the rad cap on the right and check coolant level in the rad.
    Check the inverter coolant level while your at it.
  7. Fixnstuff
    Fixnstuff New Member
    Brampton Ontario Canada
    Yes, it's the temperature sensor for the gas motor (ICE) to turn on the rad fans when it gets hot enough.It's not unplugged, it's broken into two pieces. The arrow points to the part that unscrews from the rad (antifreeze will pour out) and screw in the new one. Plug in the electrical connector after you remove the broken piece from it. A common problem is for the hose clamp on the hose just above it in your picture, to rust to "cornflakes" and let leak on the sensor. This causes the pins in the electrical connector (brass) to rust into a green paste and stop the fans. Problem cannot be seen until connector is unplugged. Trouble code B1476 will be set which (I seem to remember) stopped the air conditioning from working. Replace sensor and splice in a new plug-in connector to repair. Clear codes. Hope this helps someone!
  8. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    Hey new guy, check the dates on threads before you comment. This thread is 6 years old
  9. dolj
    dolj Senior Member
    8,434
    4,285
    Wellington, New Zealand
    Even so, it is good information (for new readers coming to this thread) and actually resolves this thread quite nicely. It sounds like this "new guy" knows what he is talking about.
