Gen 2 TPMS disable
Discussion in 'Gen 2 Prius Main Forum' started by PriusOwner_1, Jun 6, 2019.
  1. PriusOwner_1
    PriusOwner_1 Junior Member
    Missouri, USA
    I've seen another thread that you can jump 2 pins on the tpms ecu and disable the light, but it's different on gen 2. I was wondering if anyone has had luck with it. Below is the original post.
    Thanks
    "On the Gen 3 if you want to disable the TPMS without any warning lights, disconnect the TMPS ECU and jumper pins 5 and 7 on the connector. You can do this with a small paperclip cut and bent into a U shape. Here's the connector:
    The TPMS ECU is located in the "ECU Integration Box" located behind the glovebox:
    On the Gen 2, this is much more difficult! (the black tape trick prevails!)"
  2. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    You could just get new sensors, then if a tire gets low you will know.
    Danno5060 likes this.
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Or a good tire pressure gage and skip the sensors.
    Rph74 and Solman636 like this.
  4. Skibob
    2,912
    1,502
    Northern California
    Except when you have a small screw cause a leak on the highway like happened to me. How’s that tire gauge help then?
  5. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    It doesn't until you hear the screw clicking on the pavement or notice the tire is low, then you can see how low it is. I don't run TPMS on any of our wheels mounted with snow tires, and just check the tires regularly.
    Given that the OP wants to disable the light, it seems clear they aren't using TPMS, so a good gage is a good investment.
  6. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    Yeah, son had a blowout on the highway partially due to stale TPMS light. I had aftermarket sensors sitting in the garage waiting to get installed..... :whistle:
    So, got them installed while getting new tires at walmart. They said they couldn't register the sensors since they weren't their brand (BS?) so I used techstream. It took a few tries since this was my first time with the process even after reading through a few similar threads here. FWIW
    Solman636 and Skibob like this.
  7. Skibob
    2,912
    1,502
    Northern California
    You would need a good gage either way. The light is set to go off at 26.5 psi. Way lower than you would want the tires to be. Newer systems tell you the pressure, and you can look up the pressure and tire temp in Techstream but that won’t typically help when you are putting air in the tires.
    jb in NE likes this.
  8. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Not BS. They likely only have the TPMS tool for their brand of sensors. You can buy a less expensive TPMS tool that is brand specific, or a more expensive multi-brand tool. Many tire shops just get the tool that works with the sensors they sell. If they buy a large humber of sensors, the maker will usually include a tool for "free", or at least no additional line item cost.
  9. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Some of the newer cars beep the horn when you fill the tires to the correct pressure.
  10. fotomoto
    5,632
    3,809
    So. Texas
    Yeah, he seemed sincere plus being walmart they're not the high-pressure commissions model like other businesses so I let it go.
  11. fotomoto
    5,632
    3,809
    So. Texas
    My Clarity doesn't use internal sensors so no batteries to ever replace but instead somehow measures the circumference of the tire. I haven't yet looked into exactly how they do this.
    I know it works because I installed a slightly smaller accord mini-spare and sure enough the indicator activated. Reinstalled the original and hit recalibrate in the setting menu=light off. NICE!
    Palmoyas likes this.
  12. Skibob
    2,912
    1,502
    Northern California
    When I was getting new tires for my Tacoma before I got the Prius I asked the guy at America’s tire what TPMS sensors were because it asked when I was picking out tires. He said better you don’t have them, those older ones don’t work so well. Pretty obvious when your driving and a tire gets low on that truck. The Prius not so much.
  13. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    They use the ABS sensors and look at the difference in rotational speeds. My 2011 VW had this and I had to reset it with each tire change to/from snow tires. Still, a better and cheaper system in my opinion. No $30 sensors in each wheel, each of which has a limited life.
    It can't tell you the absolute pressures, but it will tell you when one tire is different from the others.
    #13 jb in NE, Jun 6, 2019
    Palmoyas and Solman636 like this.
  14. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    In my opinion, these are more trouble and expense than they are worth. Mandated by law since people weren't doing the basics of inspecting their tires and checking pressures, and were having blowouts as a result. Another work-around for stupidity and/or laziness.
    Rph74 likes this.
  15. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    This is the best tire gage I’ve owned. Worth every penny.
    Skibob likes this.
  16. Landon51
    Landon51 Member
    190
    63
    US
  17. Mendel Leisk
    41,143
    I'm wondering if OP needed the light out, say for an inspection? If not for that, I would just live with it, problem solved.
  18. emendia
    emendia Junior Member
    Norwalk, Calfornia
    16 responses and no one has answered the original question.
    JohnPrius3005, JahT and anonymous like this.
  19. scales1052
    scales1052 Junior Member
    lexington park MD
    I
    And I wish someone would. My dealer tells me the TPMS ECU is bad in my 2006 Prius, and they CANT get a replacement. So, the light will stay on unless someone here can tell us how to disable the it on a Gen II. The only thing I've learned so far it that's it's "easy" on a gen III, and "hard" on a Gen II, but no more than that. Can anyone help us?
    anonymous and ydpplqbd like this.
  20. ydpplqbd
    ydpplqbd Active Member
    551
    253
    Working on it!!!!
